Results 1 to 8 of 8
Thread: Brown water coming out filter / 1st start
    Jan 2016
    gauteng
    9
    Hi
    When the pool initially starts, a dark brown water is ejected into the pool. Clearly some form of sand. Red sand. It clears up after a few seconds.
    When i start backwash, same thing. a Thick brown mud water is ejected. After a few seconds... it turns clear. I rinse... and repeat a few times. Set pool to filter. BAM! Thick brown mud water is ejected into the pool.
    Does this mean i have a leak in the pipes somewhere?
    Is my filter busted?
    Where is this stuff coming from. I recently replaced the sand in the filter.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Brown water coming out filter / 1st start
    If you had a leak in a pipe, you should have some measurable water loss over time.
    You're following the backwash, then rinse for a minute, then back to filter cycle when backwashing?
    Was the replacement sand #20 sized and washed pool sand?
    Isolated Spa - 345 Gallons
    Jan 2016
    gauteng
    9
    Hi.
    I lose about 4 - 6cm of water in a 55000litre pool every week. Not sure if its evaporation. But i have to top up weekly.
    Yes the sand was bought from a reputable pool shop. So im assuming it has those requirements.
    My process is, backwash, rinse, backwash, rinse, filter
    Jan 2016
    gauteng
    9
    So i reckon there is something wrong with my sand filter.
    Backwash pumps out thick brown mud water. Does not matter how long i backwash, if i filter again same story.
    My pool went from crystal clear to bright green in 5 minutes. After having backwashed and then set to filter.
    Will buy new sand replace. See if that helps. I can then also inspect the bottom fins to look for any damage.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    Have you tried deep cleaning your filter
    First and foremost if your pool has turned green it could be a chemistry issue. What are using to test your water?
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jan 2016
    gauteng
    9
    Quote Originally Posted by Jezza View Post
    simple test strips. got tired of the drops method. Will have to call someone to come redo the piping. Sadly the system is extremely old and just unscrewing a pipe to perform a deep clean is not possible. Everything is stuck in place and the slightest change will result in perma leaks.
    30,431
    Where is gauteng??
    Sep 2013
    Connecticut
    728
    Appears to be in South Africa...?
    4-6 cm water loss in a week is quite a bit. Depending on the climate, it might indicate a leak. If the weather is hot and dry at the moment, it might be normal. Try doing a 'bucket test' -- essentially filling a bucket with water, setting it on a step in the pool in order to give it the same environmental conditions as the rest of the pool, and then observing if water drops more quickly in the pool than in the bucket.
    Quote Originally Posted by croco View Post
    You said you recently replaced the sand -- how did you do that if you can't open up the filter?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
