Thread: pool noodle and skimmer?
    Jun 2016
    Phillipsburg, NJ
    1
    This weekend will be my first time closing the pool and I have my wife mostly convinced it's under control (thanks to all y'all at TFP!). I think I understand most of it, except for a silly question about using a pool noodle in the skimmers after the skimmers are plugged.
    Do I coil the noodles like a snake in the skimmer basket? Tear the noodle into large chunks? Doesn't the foam float (and then not work to absorb ice expansion)? Do I use a whole(ish) noodle or just part? I don't get it.
    Thanks in advance.
    2000ish inground vinyl 20,000 gal, rectangle
    Hayward pump and cartridge filter
    Well Water, Borates, TF-100 tester.
    Messman750's Avatar
    Jun 2015
    Groton New York
    33
    Re: pool noodle and skimmer?
    Take the skimmer basket out use a rubber plug for the line. Cut a 8 inch piece off the end of a noodle. Place it in skimmer. Done! Or use a gizmo and call it a day.
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
