Results 1 to 10 of 10
Thread: Pentair T40FG
    Sep 2016
    Escondido/CA
    638
    Pentair T40FG
    I'm considering installing this automatic pool filler. I've ran my pump dry too many times.
    I think I have to drill a hole in the side of the pool and then tunnel, under the deck. I have a water source pretty close to where I'd put it, and it seems reliable enough. I'd rather do something less invasive, but I'm about to drain and refill so it feels like now or never.
    Any recommendations? Thoughts? Warnings? I did a search and did not find anything useful.
    Anyone have a auto auto fill they like?
    Amazon.com : Pentair T40FG Autofill Automatic Water Filler with Fluidmaster Valve, Gray : Outdoor Spas : Patio, Lawn Garden
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Re: Pentair T40FG
    That is the one I have, except mine is the older ball float version. It was set 5 years ago and has worked flawlessly ever since. I wouldn't have a pool without an autofill, overflow and swg. Those three things take a lot of hassle out of pool care.
    Another option is a hose on a hose timer or an irrigation line on an irrigation system. You could set it to run 10, 20, 30 min per day or whatever keeps it at the right level.
    Sep 2016
    Escondido/CA
    638
    Re: Pentair T40FG
    Thanks! Any thought as to how to drill a 1.8" hole through the gunite?
    Sep 2016
    Escondido/CA
    638
    Re: Pentair T40FG
    Ok. 2" core drill on its way. I plan on using marine epoxy to seal it back up once the PVC pipe is in.
    DFW, TX
    24,748
    Re: Pentair T40FG
    Let the fun begin!
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Re: Pentair T40FG
    Automatic Water Level System
    I much prefer this style. They should have one at PEP
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Sep 2016
    Escondido/CA
    638
    Re: Pentair T40FG
    Thanks Brian. This one looks far easier to install too.
    Re: Pentair T40FG
    There are some that connect to a garden hose and sit on the deck.
    Support the site
    Sep 2016
    Escondido/CA
    638
    Re: Pentair T40FG
    And way cheaper. Thanks Brian!
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Re: Pentair T40FG
    -Brian-
    POOL BUILD
