Thread: Should I see air pocket on top of strainer cover
    Apr 2016
    Erath, LA
    43
    I recently installed the "Hayward SP2303VSP MaxFlo VS" and I'm noticing that I see air accumulating at the top of the strainer cover.
    It goes away at higher speeds but returns at lower speeds.
    My old pump was not variable speed so I didn't see air in cover after about a minute of starting the pump.
    Is this something that I should be worried about?
    (16 X 32) 24,000 Gallon SWG, Rectangle, Vinyl lined, 1.65 HP VSP, Sta-Rite 3 part Cartridge filter, Hayward T-15 Chlorine Generator.
    Southern Louisiana
    Mod Squad pooldv's Avatar
    DFW, TX
    24,077
    Re: Should I see air pocket on top of strainer cover
    Nope, it is normal to have a little air in the basket at low speeds.
    Apr 2016
    Erath, LA
    43
    Quote Originally Posted by pooldv View Post
    Thanks!
    Southern Louisiana
    ka8yiu's Avatar
    Aug 2016
    SW FL
    108
    I have been wondering aboutthis exact same issue, and was searching it today. Exact same Hayward VS, and a small bubble becomes an air pocket as the day progresses. Higher speeds alleviate it.
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
