Results 1 to 9 of 9
Thread: Got a new liner (FINALLY) and need to close. Help!
    DontFillitin's Avatar
    May 2015
    Birmingham/AL
    377
    Ok, I read closing in pool school, but those of you know me know I always have questions and doubt my own understanding. I got a new liner Thursday and the water level is back up. Leaves are a huge problem here. The pool store said (I know lol) said to just get the chlorine and TA up, and to not worry about anything else. My gut tells me to get PH and CYA up to level as well. They also didn't recommend draining below the returns, which I honestly don't think has ever been done in this pool anyway. While Temps do get below freezing here, it usually isn't for very long. If it does, can't I simply turn on the pump overnight? I already saw that I need to get polyquat so I guess today is out of the question unless I can add it after the cover is on. I had planeed to pull the cover back after the leaves finish falling and test and treat, then again after the new year. Am I making this more complicated than it should be as usual?20161015_154918.jpg
    25,000 gallon IG with vinyl liner. Not sure how old it is. Sand filter, not sure what brand/size, Hayward Super Pump c48k2n143b1. I have a Polaris 180 cleaner on it's last wheel (haha). I'm still not sure about water restrictions, but haven't gotten any hate mail about the amt I used last summer. I absolutely LOVE my TF-100 test kit.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Re: Got a new liner (FINALLY) and need to close. Help!
    Hi,
    Us folks in the southern region of the US really dont need to "close" our pools. Some folks do cover it though.
    There is no need to drain below the returns.....
    I would recommend to balance the pool (dont worry too much about the CYA though), then bring FC up to SLAM level, then cover it. You can add polyquat if you want to. (when you add it isnt of any large importance).
    Then cover it.
    When the temps threaten to drop down to freezing, then turn your pump on and you'll be fine. Moving water requires lower temps for longer periods to freeze.
    A couple years ago, we had temps of 20 and below day and night, for more than a week, and I didnt have any problems at all.
    Divin Dave,
    May 2015
    Birmingham/AL
    377
    Thanks for confirming what the marble in my head was trying to say, Dave!
    Aug 2014
    Northern IL
    4,615
    Trust the marbles!
    May 2015
    Birmingham/AL
    377
    It's only one
    Aug 2014
    Northern IL
    4,615
    Use whatever you've got!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    BUT that marble did help you find TFP were there are a couple of other marbles rolling around ready to help!
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,388
    That looks like "dynasty blue granite", depending on the distributor. Absolutely get your ph dialed in, that is a quick fade pattern.
    May 2015
    Birmingham/AL
    377
    Quote Originally Posted by MarianParoo View Post
    Yes yes!
    Quote Originally Posted by kimkats View Post
    Very true!
    Quote Originally Posted by PoolguyinCT View Post
    Thanks for the heads up! It (was) 7.6 iirc
