Thread: Decking options
    Aug 2016
    Parker, Tx
    2
    Question Decking options
    We are close to finalizing our pool design, but are having a hard time making a decision on the decking. We currently have a large stamped concrete patio that the new decking will need to tie into. We originally thought we just wanted to use stamped concrete again, but the PB we are leaning towards suggested using pavers instead. He indicated pavers would not be as slick as the stamped concrete, and would be a little cooler in the hot summer sun. We have enough of a threshold on the existing patio to put pavers over the existing stamped concrete and then use the same pavers for the new decking as well. My wife wants to be able to power wash the new decking, and we don't know if pavers would be a good option for this. Are there any opinions of stamped concrete vs. pavers? Are there any other factors we should consider?
    Jan 2016
    Mesa, Az
    540
    Re: Decking options
    If you powerwash pavers, you'll wash the sand out of the joints and need to re-sand every time. Even polymeric sand won't hold up to a pressure washer. I just use the hose nozzle and lightly flush the surface dirt off if I feel the need to clean the deck. It really doesn't get dirty unless you get spray-on sunscreen on it.
    May 2015
    Fullerton, CA
    634
    Re: Decking options
    I have pavers, absolutely non-slip, great looks, cool in the 95 degree sun, NOT! A hose with pressure nozzel is all i need to wash them down. Like pavers much more than concrete.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,259
    Re: Decking options
    I think a concrete deck will be cooler than pavers. We have rock salt finished colored concrete deck. It is great; no upcharge, non-slip, zero maintenance and looks great after 5 seasons. Pics in link in sig.
    texasgal78's Avatar
    Feb 2016
    Prosper, TX
    87
    Re: Decking options
    We have have the salted concrete as well and it wasn't slippery, looked great, and never got hot...and we are Texas
    Tried finding a pic on my phone...
    My 2016 pool build Owner build 104' free form IG sport pool,20'x36' (18,300 gal)~7'x8' raised spa with spillover~Oklahoma flagstone coping~12" raised beam with dry stack wallC~Cascading waterfall grotto with flat moss rock~630 sqft salted concrete deck~Deep blue sea-prism matrix~2 Hp Jandy epump~1.5 Jandy stealth~CL580 cartridge filter~Jandy jxi heater~iaqua link 2.0 ~dolphin m500 robot~LED pool lights (2 pool, 1 spa)~TF-100 test kit
