Taylor k-2006 Test kit- FC- 3.6 PH 7.0 TA-120 Can't get CYA to measure. Thoughts?
In Ground, 36'x14' Gunite w/StoneScape. IntelliFlo 2 VST, Pentair CCP520, Pentair 400 Heater, Taylor k-2006. Built 9/2016
Sounds like there isn't any CYA in the pool. Or testing error.
The R-0013 reagent is fairly bullet-proof and almost never goes bad. Any CYA level less than 30ppm will result in a clear water sample when testing. You likely have less than 30ppm CYA.
Matt
16k IG PebbleTec pool, 650gal spa, spillway and waterfall, 3HP IntelliFlo VS / 1.5HP WhisperFlo, Pentair QuadDE-100 filter, IC40 SWCG, MasterTemp 400k BTU/hr NG heater,KreepyKrauly suction-side cleanerDolphin S300i robot, EasyTouch controls, city water, K-1001, K-2006 and K-1766 test kits, Mannitol test for borates
