Results 1 to 15 of 15
Thread: which RayPaK heater?
    Mar 2015
    South Texas
    411
    I have searched and searched and just need a bit of advice....
    From reading on here, a Raypak gas heater is the way to go. So which one? We have a 15K gallon pool and live in South Texas where we will only use it from October to March. Thoughts? My instinct is to to buy the 40K BTU one for fast heating. Is it like a SWG where bigger is better?
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,698
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad pooldv's Avatar
    DFW, TX
    24,230
    Re: which RayPaK heater?
    You are on the right track. It will basically cost the same amount of money to heat your pool. A bigger heater will just do it faster.
    Mar 2015
    South Texas
    411
    Thanks guys!
    Feb 2012
    Phoenix, AZ
    728
    Since you do have a SWG I would suggest looking at a Cupro-Nickel model (as opposed to copper), the heat exchanger is more resistant to corrosion that can come from chemical imbalances and salt corrosion. Might be a little more upfront but could be worth it long term. Raypak is a great brand choice as well, quality heaters.
    Mar 2015
    South Texas
    411
    Quote Originally Posted by PSW View Post
    Any models you would recommend?
    Feb 2012
    Phoenix, AZ
    728
    The Raypak 406A series, and model # 014941 is the Cupro-Nickel version. That model is Natural gas and also standard emission, I'm assuming you wouldn't need the Low NOx version which is a code requirement in some counties.
    I have one, its 4 or 5 years old, gas has been off to it for about 3 months, I fixed the gas line and now it will not fire up. The pilot lights and then goes out and I get the IGN code. I pulled the front off and there is a lot of rust. Going to try to clean it all and see if that helps I must say not to happy
    Mar 2015
    South Texas
    411
    Well after looking into it gas is not a real option for us. Gas line is about 100 feet away and to have it run to the equipment pad would be super expensive. Looking into heat pumps now. I believe in my case a heat pump is almost as good an option but mostly because we're in such a warm climate. Any models/brand suggestions would also be helpful.
    DFW, TX
    24,230
    I agree that a heat pump will work very well in your location. It will allow you to cheaply maintain your water temp all the time. Heat pumps are basically just a home HVAC heat pump with a water exchange instead of an air exchange. You can stick with Hayward if you are happy with the brand.
    Mar 2015
    South Texas
    411
    Quote Originally Posted by pooldv View Post
    Thanks PoolDV! I have been happy with all of my Hayward products. I have read that some models heat and cool. Any suggestions on model?
    DFW, TX
    24,230
    Yes, they are available with and without cooling mode. If your pool is too warm in the middle of summer cooling is a good option. I use my solar panels to cool my pool in August by running them at night.
    It looks like the HP31154T, here, HeatPro Heat Pump | Heaters | In Ground Pool Heaters - Hayward Pool Products, would be the best option if you are looking for cooling also.
    Mar 2015
    South Texas
    411
    Thanks PoolDV! That sounds like exactly what I need. They are proud of them, no doubt! Time to start saving.
    DFW, TX
    24,230
    Yes, they aren't cheap. Check INYO Pools and Sunplay. They usually have pretty good prices and both do a great job.
    If you are willing to be diligent with the cover and plan ahead you might do ok with with a smaller heat pump like the HP50TA or HP50HA. I have the HP50HA and it heats my pool (20k gal) about 1 degree every 3 or 4 hours and seems to be able to maintain temp so far. But, I just installed it a few weeks ago and don't have a lot of experience with it yet. It also has cooling.
    More here, Heaters | Above Ground Pool Heaters - Hayward Pool Products
    The deal with heaters is that it costs about the same money/energy to heat your pool X degrees no matter what size the heater is. A bigger heater will just do it faster.
    Mar 2015
    South Texas
    411
    great to know. Thanks pooldv!
