Thread: Impower pump motor problem
    Oct 2016
    Winter Haven florida
    2
    I have a marathon impower pool pump that runs normally and after a while the display leds and the switches stop working. When the pump is powered off the pump starts working normally and runs for approx 1 hour and then fault reappears. I noticed that someone had resolved the fault and wondered if they could let me know what they did.
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Re: Impower pump motor problem
    Welcome to the forum.
    I did did a forum search and don't see too many threads on your pump, and the one I found that was similar did not post a fix. The member has not posted since 2014:
    impower, sntech pump motor problems
    Hopefully this bump will get your thread some more attention.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Oct 2016
    2
    Thank you for looking. I also thought I had solved it. I noticed the 5v regulator chip showed signs of running hot so resoldered it and ran the pump without the cover for the control board. It
    Ran all day with the leds still on. However when I reassembled it the reapeared.
