Thread: New at closing
    Jun 2016
    Cincinnati, OH
    39
    New at closing
    So I have read up on the closing above ground pools here and I think I'm understanding it all. I brushed and vacuumed today and added algaecide. Covered it up to keep stuff from getting in it. Was going to let it run till tomorrow to get the algaecide mixed in. Was considering adding in 10% liquid chlorine as well. I have 4 jugs of it but dunno if I should add it. FC is already at 17. Ph is 7.8. TA is 80. CYA is 60. I'm planning on using 2 air pillows under the solid cover. As well as a winter pill.
    Few questions
    -should I use more liquid chlorine? Or just let it go at 17. I hate leaving those new jugs of 10%. But considered storing in the basement until I open it.
    -should I use a gizmo or a skimmer face plate? I am torn on this decision. I can see leaving everything open so it drains. I have purchased both but dunno if either is needed.
    - can I leave my pump and filter housing outside in the winter but covered up? I plan on bringing the cartridge in but wasn't going to bring in the housing itself. It's all piped up together. I can disconnect though if needed.
    27' Aqua Leader Quantam AGP 19,300 Gallons
    Hayward 2HP pump, hi-low speed
    Hayward Swim Pro 175 sq ft cartridge filter
    K-2006 test kit
    Wedding Cake steps
    domct203's Avatar
    Jun 2015
    CT
    3,508
    Re: New at closing
    Quote Originally Posted by dleague View Post
    Few questions
    The TFP Closing your Above Ground Pool article states to raise your FC to shock level for 24 hours as insurance against a late algae bloom. With a CYA of 60ppm, FC shock level is 24ppm. Did you do that before adding the algaecide, and was it Polyquat 60?
    A "winter pill" is not part of the TFP closing procedure. Do you even know the chemical content of that "pill"?
    If you have drained below the skimmer and removed all hoses there is no need for a faceplate or gizmo.
    It is recommended in the TFP closing procedure that you store your pump indoors for the winter.
    It is also recommended in the TFP closing procedure to cover any filter left outdoors to protect it from debris, snow, ice, etc.
    I close my pool with nothing but shock level FC, cold water, & a solid cover with pillows.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
