Thread: Struggling to keep pH down
    Oct 2016
    Austin TX
    6
    Hi all. I seem to be frequently adding acid to keep pH in a reasonable range. It will rise to 8.2 within a few days of bringing it down to 7.5-7.8.
    This morning's test results after adding 18 oz of acid yesterday afternoon:
    FC 7.0
    CC 0
    pH 7.5
    TA 70
    CH 400
    CYA 60
    The table below shows abbreviated test results and acid added as a result. I use PoolMath to determine how much acid to add for a target of 7.5.
    Date TA pH Muriatic Acid Oz
    09/30/2016 80 8 18
    10/1/2016 100 7.8 11
    10/04/2016 80 8.2 18
    10/05/2016 80 7.8 9
    10/08/2016 80 8 18
    10/11/2016 90 7.8 9
    10/14/2016 90 8.2 18
    I mostly have the water fountain turned-off to keep aeration from increasing the pH.
    Is this just normal for my pool or is something else affecting pH?
    Steve
    First time pool owner April 2016 | 11,300 gallons IG Plaster with Water Fall | Tagelus TA 50 Sand filter | Jandy SHPF Pump | Polaris PB4-60 Booster Pump | Polaris 280 Cleaner | TF-100 Test Kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    6,041
    Re: Struggling to keep pH down
    Steve,
    If this is a new pool or has new plaster, that will cause pH to rise. Your waterfall (aeration) will also cause pH to rise.
    I suggest you try this...
    Measure and record your TA. Use pool math and drop your pH to 7.0 and immediately turn on your waterfall. Wait three or four hours and measure and record TA again. Measure pH and then add acid to drop it to 7.0 again. Wait three or four hours and measure TA and pH again. Do this same process over and over, until your TA drops to 60 and then let the waterfall run until your pH gets back up to 7.5 or so.
    Oct 2016
    Austin TX
    6
    Thank you for the recommendation, Jim.
    The pool is about six years old.
    Steve
    30,133
    This is the process that Steve describes.....
    Pool School - Lower Total Alkalinity
