Thread: Intermatic T104r3 won't manually turn on
    Oct 2016
    Chandler, AZ
    1
    There does not appear any way to turn my pump on manually. The manual off/on switch has no affect. Am I missing something? I tried changing the time (like on a light timer) until it turns on but that didn't work either. I'm wondering if by touching it, I broke it.
    Jun 2014
    16,102
    Re: Intermatic T104r3 won't manually turn on
    Hello and welcome to TFP! The manual override should work, but weird things do happen. I found this troubleshooting chart that might help you until more response get posted. Great to have you with us.
    Apr 2015
    tucson, arizona
    1,205
    Check the voltage coming into the timer, should be around 220v, also check in th little visual window for the motor wheels turning. If all okay then the contacts on back of timer are not moving when you manually turn on. Also check voltage at the load terminals with switch on, if it's 220v then something wrong at motor
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,712
    I have been having trouble with the t104 timers. Been noticing that the firemans switch has been interfering with the cam lobe. If you have a firemans switch on your timer, try loosening the two phillips screws that secure it to the backing plate, and re-adjusting it back a bit further away from the cam.
    Factory Warranty Station for:
