Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Pool Math and FC?
    Feb 2013
    Jupiter, Florida
    73
    Pool Math and FC?
    Pool Math tells me that my FC should be a minimum of 4 with a Daily Goal between 9 and 11 yet the suggest level listed elsewhere on TFP say much lower.. like 3-5. Why is this? What should my FC level actually be?
    2006 IG 18.6K gal marcite saltwater w/integrated 800 gal spa, spillover, 2 Main and 2 Spa Drains, 2 Skimmers
    Goldline Aqua Logic PS-8, Aqua Pod Remote, Hayward GLX-Cell-15-W SWG, Hayward Pool Vac XL, Cartridge filter, single speed pump
    Taylor K-2006, Lamotte Borate Strips
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,940
    Re: Pool Math and FC?
    Your recommended FC depends on what your CYA level is. 7.5% minium to 11.5% of the CYA.
    Pool School - Chlorine / CYA Chart
    Divin Dave,
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Quote Originally Posted by firstbase View Post
    What's your CYA reading?
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Feb 2015
    Chandler AZ
    745
    Minimum and target FC are different for SWCG versus non-SWCG. I think that's where you are seeing the differences. Refer to the Chlorine / CYA Chart that Divine Dave linked to in post #2
    If your SWCG is operational and you are actively using it to chlorinate the pool use the SWG Pools section of the chart. If manually chlorinating the pool use the Non - SWG Pools section of the chart.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Feb 2013
    Jupiter, Florida
    73
    Quote Originally Posted by proavia View Post
    No, I am using the numbers from SWG chart a well as the Pool Math numbers. Those are the two set that don't agree. My CYA...well, don't get me started on reading that test. Have no real idea what "Until you can't see the dot" actually means. Yesterday CYA read at 78. Today it reads 65. Mor accurte to say "I read it at...". This is another subject/thread though. Lets pretend my CYA is 70 then I should be 7.5% to 11.5% which would be 5-8 FC.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,078
    It sounds like you are reading the target for non-swg pools in PoolMath.
    Mine says this for CYA 70
    SWG Minimum: 3 non-SWG Minimum: 5 Daily Target: 8 to 10
    Which matches this
    FC/CYA Chart
    Feb 2015
    Chandler AZ
    745
    Ok, i think i see what you mean.
    In PoolMath it shows a SWG minimum, a non-SWG minimum and a target. But the target displays a numbers range for non-SWG. I don't see a target for SWG. Maybe the SWG target can be added at the next update to PoolMath - maybe not. In the mean time, refer to the CYA/Chlorine Chart. Maybe even print that chart out and keep with your testkit.
    EDIT:
    If your CYA is between 2 numbers on the test vial - round up. So between 60 and 70 - dose for 70. Plus or minus 10 is well within the error margin of the test.
    Last edited by proavia; 10-16-2016 at 12:52 PM. Reason: Spelling - dang auto-correct
    Gene
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    CYA is the most subjective test you'll do and it is frustrating. After you do a lot of them you'll feel better but never will you be happy. Just make sure you keep the FC where the Pool Math indicates for your "estimated" level.
    Feb 2013
    Jupiter, Florida
    73
    Quote Originally Posted by Frankhugus View Post
    Thanks...so listen to Pool Math not the SWG CYA / FC chart then. Pool Math says 8-10 for my tests w/CYA at 70. Chart says FC at 5 w/ CYA of 70. I'm probably overthinking this..obsessing with the numbers right? How much difference can 4ppm chlorine matter and who can keep it that stable?!?! With South Florida rain, overflow, refilling or South Florida evaporation and refilling, wife mowing the lawn around the pool (into the pool), etc etc etc....hard to keep chlorine and pH at any one level for more than 24 hours.
    JoyfulNoise's Avatar
    May 2015
    12,178
    Could always buy one of these if you're really bothered by the test so much - Cyanuric Acid Portable Photometer - HI96722 - Hanna Instruments
    Matt
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    299
    Must...buy...immediatley....Resistence futile.....Have..no..choice....
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    May 2015
    12,178
    Quote Originally Posted by Jaimslaw View Post
    I prefer to spend $200+ dollars on restocking my beer fridge...
    Matt
    May 2015
    12,178
    Also notice that all you get for the $220 is the meter and two sample cuvettes. You still need to buy the reagent packs ($110) and the calibration standards ($140). The cleaning solution and microfiber clothes are probably a good idea too.
    So now you're looking at a $600 instrument when all is said and done....I'll leave the cost/benefit analysis up to the individual on this one....
    Matt
    Jul 2014
    Hope Mills, NC
    561
    And it only measures to 80 ppm.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    299
    Yeah...way too much. Using $$ to buy and drink many beers infinintely preferable. Besides, I am able to render myself invisible after drinking a six pack.
    Aug 2014
    Houston tx
    2,498
    And I thought making beer disappear was your superpower...
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Feb 2013
    Jupiter, Florida
    73
    Oh, a bunch of FUNNY guys eh?!?!? With my luck I would spend the $600 only to find out that, after completing the 17 steps to set up and calibrate the thing, you get your result by submerging it in the pool and measuring how deep you have to push it before the black round knob disappears from your sight.
    The only superpower I want right now is the super ability to tell 60 CYA from 80 CYA...
    DFW, TX
    24,078
    Just dose for 80 and be happy. It is only 2ppm more fc. More FC is always better than less. It is safe to swim up to shock level for your CYA. It is not safe to swim below minimum for your CYA. FC/CYA Chart
    Beer fridge?
    Jul 2014
    Hope Mills, NC
    561
    Dump everything out on the top shelves and refill with more Shiner Bock!
    Vinyl in-ground
    1 HP Pump
    Hayward SWG
  20. Back To Top    #20
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    866
    Quote Originally Posted by Griswald View Post
    I'll take that Boddington so you don't have to worry about it and you can keep that clear bottled stuff...
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
