Trying to get leak found and repaired
A year ago I got our spa going with some help from a local spa tech. After the major problems were dealt with we starting using the spa through the cold season. However, there was still a leak to be fixed. After topping off the water level, it would take 10-14 days to reach the lower operational level. The floor around the spa remained wet and when the spa was turned off, the floor would dry up and I did not observe leakage. I turned off the spa for the summer and would like to find and fix the leak and put it into operation again. Is this a proper forum to log what I'm doing and ask for some advice?
