Results 1 to 18 of 18
Thread: WaveHeater- anybody have this?
    Jan 2016
    Portland, OR
    36
    still researching a way to heat my in-garage pool...and I find this exists: Amazon.com : The 2016 WaveHeater for above ground pools : Patio, Lawn Garden
    I did a search here and didn't see any relevant threads. Anybody own it/love it/hate it?
    Bestway 18X9? steel frame pool, AG, approx. 4K gallons as of 1/5/2016, sand filter, 1/2hp single speed pump, all set up on foam flooring squares set in my insulated and finished garage.
    Portland, OR USA
    eblade21's Avatar
    Jun 2014
    Lynbrook, NY
    23
    Re: WaveHeater- anybody have this?
    Hi Dgephri
    I was curious if you ever found an answer to your question? Did you purchase the Waveheater?
    Thank you
    Eddie
    Eddie
    Summer Escapes 14' Pro-Series 4047 gallons; Intex 12 inch Sand Filter Pump; Intex SWCG; Vinyl Works Fence; Taylor K-2006C and Taylor K-1766, Intex 14 Inch Sand Filter Pump
    Sungrabber 4 x 12 feet Solar Collector controlled by Hayward Aqua Solar GL-235
    12 mil Clear Solar Blanket on SolarRoller; Aquabot Reaction
    Jan 2016
    Portland, OR
    36
    I am about to...it is left standing as the only real option for my in-garage pool...I should have a report in a couple weeks - order, arrival, install, testing, etc.
    Portland, OR USA
    Jan 2016
    Portland, OR
    36
    it showed up today...a little bigger than I imagined from the YT vids. So, he recently made a change that the WaveHeater should go BEFORE the Sand Filter instead of After it.
    Is there any real reason I can't just reorient my hoses to use opposite ports from A to B? I am currently using the Intex skimmer, so it won't change the actual inlet depth...thoughts?
    Portland, OR USA
    38,475
    Some math:
    4000 gallon * 8.3 = 33200 pounds of water.
    Takes 1BTU raise 1 pound of water by 1 degree F
    So, you need 33200 BTUs to add 1 degree
    Link claims 18770 BTU/hour .. so it will take 1.77 hours to add 1 degree (assuming good efficiency) ... Lets round that to 2 hours to add 1 degree for math's sake.
    Running it for 2 hours to add 1 degree will use 5500watts*2 hours = 11kW-hr per degree increase. Average electrical cost is $0.12 / kW-hr (obviously this can vary greatly).
    Cost to add 1 degree approx. $1.32 and it will take 2 hours.
    Run it for a day and it will cost ~$16 and will add 12 degrees .... assuming no large losses.
    BTW, putting it before the filter seems like a really bad idea.
    Jan 2016
    Portland, OR
    36
    thx, I know the math for heating: but inside my garage it already averages 72-74F in the summer, and 64-67F in the winter. I have found no other way to add heat so I can get year-round control.
    I figure a couple times a week, I can pop it on for 6-8hours while at work, then have a 78-80F temp for some evening swims. I have been watching my evening-morning temps and I usually lose 1-2F at night.
    The issue before/after the sand filter is that on the exit from the Sand Filter, "most" of them let a little sand out. This can potentially clog the flow switch and it will fail. Putting it before the sand filter means that sand will have exited, and settled on the pool bottom (if any) and prevent that. According the manuf.
    I wish my arrangement let me use a Hayward, or anything else, but it does not.
    The main question is if reversing "A" and "B" ports for flow direction will do something.
    Portland, OR USA
    38,475
    I have no idea what ports A and B are.
    1. Your sand filter should not be letting sand through
    2. If you put the heater before the filter, then leaves/debris can clog up the heater.
    Jan 2016
    Portland, OR
    36
    I always understood that the "higher" port is for the pump flow out, and the "lower" port is for the strainer/skimmer in. What if I reverse the purpose of those two ports?
    This pool is in my garage, so no leaves, only the occasional vacuum for settled remnants. I posed that question to the manufacturer and it just reduces the problem. Their claim is that it's a very small amount, but this is a preventative change in their directions.
    Portland, OR USA
    38,475
    I guess switching them should not matter ... but I do not fully understand the reason you want to do so.
    Jan 2016
    Portland, OR
    36
    thanks. I have a small space between the side of my Pool and the garage wall, and the pump/Sand filter combo barely fits, then I have the watertight conduit coming to the WaveHeater on the pool inlet side. Now I find out I need it on the pool outlet side.
    If I reverse hoses and twist the top of the sand filter, I might be able to save about 20' of hose in hooking up the WaveHeater. I just didn't want to create another new problem in the process without checking here.
    Portland, OR USA
    Jan 2016
    Portland, OR
    36
    after an hour on the phone with the manufacturer (Dave, has been really great in helping me figure out my strange install situation!) going through wiring step by step, I had to reroute some hoses.
    Particular issues with the unit:
    1. 30amp GFCI breaker required at 220V
    2. he sends you a little transformer (doorbell type I think) that gets wired in to make the Flow switch trigger the GFCI
    3. Heater must go between Pump and Sand Filter, as his service calls over the years have led to finding a VERY small amount from the Sand filter contributes to some failures?
    4. Heater has an air port/valve that has to be up and fairly level should any bubbles get trapped in the unit.
    My garage set up makes it a bit strange, but I am expecting to be testing flow, GFCI trigger, and Heating power today and tomorrow to be sure it's all going to operate as it should and be safe like it should.
    So if you have a cartridge filter: few issues. If you have a sand filter: you need this BETWEEN the pump outlet port and the Sand Filter inlet port.
    Portland, OR USA
    Jan 2016
    Portland, OR
    36
    got to juice it up last night. Passed all my GFI testing, flow action, etc.
    8:10pm temp was 72.5F from my Bluetooth sensor at the opposite corner from my outlet
    10:10pm temp was 73.9F same location
    Given the decimal reading might still have a little error, and I purposely put the temp sensor in the corner opposite from the water outlet port, I didn't quite reach my target of 1F/Hr.
    I will run more tests of longer durations to see when diminishing returns occur, and since my garage is fully insulated, there should be some heat gain back and forth in the airspace, and then heatsink shared with the water etc. Even in 90+ temps in Oregon, my garage is sitting about 75-77F.
    More as I have more temp figures over the coming weeks. Otherwise - it's the only product I found that can work in my weird and difficult situation.
    WaveHeater as a product, and the owner as support, has been GREAT though!
    Portland, OR USA
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Quote Originally Posted by Dgephri View Post
    What do you mean by "trigger the GFCI"? A GFCI is a protection device that when activated disconnects all power on the load side.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jan 2016
    Portland, OR
    36
    If you are running the heater and the pump stops for ANY reason, the heater's flow switch is triggered, and my GFCI 30A 220V breaker trips to the middle position. The transformer gives the Flow switch a little help in ensuring the GFCI gets a differential to protect the Heater, the people, and the circuit?
    Not an expert, but we tested it twice.
    Portland, OR USA
    May 2012
    Bklyn, NY
    1
    Is this type of heater only for intex pools? I have an aluminum AGP 8x19. I only need to raise the temp 5-10 deg at most.
    Johnny-M
    Altoona, Pa
    35,000 gallon in ground pool. Lazy L shaped
    Vinyl liner.
    300# sand filter
    3 Returns, 2 skimmers, and No bottom drain
    2hp pump
    Jan 2016
    Portland, OR
    36
    I don't think it's limited to Intex. Contact David via his website. He was super helpful and we worked through the details of my strange situation. I bet he can help analyze your needs.
    Portland, OR USA
    May 2017
    Wheaton, Illinois
    2
    So how do you like the Waveheater, Dgephri?
    Just heard about it and found this thread.
    Jan 2016
    Portland, OR
    36
    It's working quite well in my opinion:
    1. check temp of Pool on my Bluetooth sensor
    2. estimate how many hours I need the Heater to run
    3. head to the garage, turn on pump, walk around to the panel and hit the breaker for the Heater.
    4. set kitchen timer/phone timer to remind me of the duration
    5. check the temp during the interim
    6. swim
    Logged more time in the pool this last month with Heater than most of the previous 1.5 years needing a wetsuit for cold temps.
    I haven't had a full month to check my power bills but so far I've needed less than 12 hours per week, so it should be about $60 a month for the Heater increase.
    Portland, OR USA
