Results 1 to 8 of 8
Thread: Plumbing Size
    Jun 2016
    Fort Worth, TX
    19
    Plumbing Size
    Hi Everyone. Our builder installed 2" suction lines and 1.5" returns but our contract is for 2.5" suction lines. They are changing the suction lines to 2.5" and keep the return lines at 1.5". Is this sufficient or should the returns line be changed to 2"? Please help as we know nothing about pool and plumbing. Just feel like this isn't right.
    Thank you so much.
    Sep 2016
    Gilbert/AZ
    36
    Re: Plumbing Size
    Depends on how many return lines you have I guess. If you had a single 1.5"return that later split into several, this would limit your flow. If you had several 1.5" returns right after filter, then I would think it would be ok. Bigger always better though. Someone with better info will be along shortly.
    12,750gal, pebbleTec 30'x15' 3.5'-4.5'-7', 88'perimeter, 420sqft, 3x 2" looped infusion returns, A&A G4v infloor cleaning, Quickskim venturi skimmer, leaf vac, Hayward tristar VS, 520sqft cartridge, P4 ProLogic automation, Tcell-15 40k SWG, Multi ColorLogic LED, 2.5" plumbing. TF-100 K-1766 speed stir.
    Jun 2016
    Fort Worth, TX
    19
    Re: Plumbing Size
    Thank you. We have 5 returns and here is a picture, hope this will help.
    Apr 2015
    tucson, arizona
    956
    Re: Plumbing Size
    It usually depends on pump size and the flowrate your trying to achieve. 1-1/2" pvc is for 40-50 GPM where 2" is 70-80 GPM. If all those lines are returns to the pool and kept in the present valve config, then I don't think it will matter. On the left hand-side you have three lines with valves are they labeled, do you know what each line is for?
    Jun 2016
    Fort Worth, TX
    19
    Re: Plumbing Size
    Quote Originally Posted by kadavis View Post
    No label yet but I will ask my PB. Thank you!
    Dec 2014
    Riverside California
    474
    Re: Plumbing Size
    Also please re-think that chlorine tab feeder. Most members of this forum will tell you to forget the tabs and go with the TFP bleach method.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    mas985's Avatar
    Pleasanton, CA
    11,544
    Re: Plumbing Size
    Is that a cartridge filter? If you have too little head loss on the return side vs the suction side, that can put a pump into cavitation. I would say leave it as is or you could create a problem. What is the filter pressure when the pump is on full speed?
    Mark
    Jun 2016
    Fort Worth, TX
    19
    Re: Plumbing Size
    Quote Originally Posted by mas985 View Post
    Oh no. We can't run and test it yet. It is there but not really connected to anything. I will forward this question to pb.
    Builder says since I don't have a spa it should be ok. Our pool is 17x35 rectangle pool, no spa, 5 returns, 3 sheer descents and 1 bubbler.
    Thank you.
    Quote Originally Posted by gary300 View Post
    Thank you we plan to use TFP method but the tab is for when I'm out of town on business. Appreciate you pointing it out, making sure we don't miss anything with out build.
