Thread: Cloudy pool
    Cloudy pool
    Earlier I had a yellow algae problem.. and after using the method by bleach slamming.. it all got back to crystal clear pool in 3 days..
    After which I maintain the chemical level using granular 70%. I had the following readings:
    FC 1.8
    TC 2.0
    PH 7.4
    CYA 15
    TA 25
    Then, in order to increase by CYA, the following week I put in trickle tablets and after a week, when the tablets started to finish, readings were :
    FC 1.4
    TC 2.0
    PH 7.3
    CYA 26
    TA 25
    And there was slight layer of algae/dirt at the pool bottom floor. I brushed and started dosing with 500g of granular unstabilised chlorine 70%..And then my pool started becoming a little blue.. but now it's slightly cloudy..and there was a few here and there tiny green algae on the grouting
    My current readings:
    FC 3.2
    TC 3.2
    PH 7.3
    TA 25
    CYA 26
    Now it's been 2 nights I am dosing 500g of unstabilised chlorine 70%.. is there something I'm not doing right? Do I need to continue this dosing until a week, as per what the pool school stated? Please advise.
    29k Gallons Inground Concrete Pool (11m x 6m) | Waterco Sand Filter S900 | 2HP Waterco Hydrostorm Plus Pump
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    5,943
    Re: Cloudy pool
    The reason that you keep having algae, is that you are allowing your FC level to go below the very minimum it should be. Your FC should really be around 4 or above. Check this chart out... Chlorine CYA Chart
    You also might want to look at your TA level... 25 seems awful low to me. Recommended Levels
    I suggest you follow our SLAM process until you have passed all three requirements. SLAMing Your Pool
    Re: Cloudy pool
    Quote Originally Posted by Jimrahbe View Post
    Hi.. having FC 4 and above is the Target.. so do we calculate to keep FC at target or at minimum? When do we use minimum?
    As for TA, I read somewhere, to no worry about TA until pool is in good condition
    domct203's Avatar
    Jun 2015
    CT
    3,425
    Re: Cloudy pool
    Quote Originally Posted by kilrathi View Post
    FC 1.8
    TC 2.0
    PH 7.4
    CYA 15
    TA 25
    FC 1.4
    TC 2.0
    PH 7.3
    CYA 26
    TA 25
    FC 3.2
    TC 3.2
    PH 7.3
    TA 25
    CYA 26
    Which test kit are you using to get these results?
    As already mentioned, your TA is dangerously low. When the TA falls below 50 the pH can unexpectedly crash down to 4-5. It would be wise to add some baking soda to get the TA up into the 50's.
    Also, you keep adding what appears to be Cal-Hypo (you mention 'granular unstabilized chlorine') but you do not post a test result for CH, a very important level for a non-vinyl pool. With all that Cal-Hypo you are adding it could be clouding the water.
    BTW- all solid forms of chlorine are stabilized, mainly with CYA, but also with calcium in the case of Cal-Hypo. You should really be using liquid chlorine, aka bleach, as that will add just FC and a trace amount of salt.
    Also, you should be following the FC / CYA Chart to slam your pool. With a CYA of 30ppm (how did you get 26?), your SLAM FC is 12ppm.
    Pool School does not tell you to SLAM for a week, or any other pre-determined length of time. A SLAM is complete when:
    1) You pass the OCLT
    2) CC is <0.5ppm
    3) The water is clear of all algae
    http://www.troublefreepool.com/conte...tain-shockingl
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
