Results 1 to 8 of 8
Thread: vinyl liner replacement
    Sep 2015
    Mobile, Al
    24
    This may not be the right place to post this but here goes. The liner in my 18 by 36 ingound pool failed because of poor installation by the previous owner of my home. I hired a company to redo the bottom and replace the liner. To resurface the bottom they basically just mixed sand and portland cement(no water), spread it with hand trowels and then sprayed wate on it and put the liner in. It is the lumpiest most uneven bottom you can imagine. What is the proper way to do this? Also is it possible to drain the water, remove the liner, smooth the bottom and reuse the same liner?
    18 x 36 IG 25000 gal Pentair 1 hp pump Pentair 350# sand filter Taylor k-2006
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,384
    Re: vinyl liner replacement
    No, once it is set the material develops a memory. (It is possible but super unlikely) sounds like they did a 3 to 1 dry pack bottom.. Done properly that is the best substrate.
    Aug 2014
    Northern IL
    4,615
    Poolguy, does that mean that once water is added, the weight evens the floor out?
    Jul 2014
    Connecticut
    1,384
    Not at all..
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Gashauler, Are you saying the people you hired did this lumpy bottom and this is your brand new liner? I have some ideas if so.
    Kim
    Sep 2015
    Mobile, Al
    24
    Yes...brand new liner. I hired him to replace liner and bottom. Tho pool isn't even all the way full yet!!
    Sep 2015
    Mobile, Al
    24
    bump
    Jul 2012
    Tallahassee, FL
    30,585
    Is there any way YOU can undo the side of the liner away from the skimmer and return to see if you can move the sand/stuff around with a little effort. Is so I could do that............take the liner down EXCEPT about 1 foot on either side of the skimmer/return. Use something to make sure the liner will stay up. Pull the liner towards the skimmer and work the sand/stuff to smooth it out.
    IF you have the $$ you can buy house foam........the pink stuff you put on the house walls. You can put it on the bottom under the liner (triple taping to keep gaps from happening). That will make for a very smooth bottom.
    Just some ideas to help you maybe get a smooth bottom on your pool.
    I hope one of them works for you. I will tell you that my installer spent a LOT of time on the bottom of my pool smoothing and such and there were still some slight dimples. You cannot see them expect at night when the light is on OR when there is dirt in the pool. The dirt gets "caught" in the dimples.
    Kim
