Thread: Booster Pump humming
    Polaris Booster Pump Motor B625 is humming away. I tried:
    Replacing the start capacitor ( same specs)
    Hitting the sides of the motor
    Spinning the shaft while the motor is humming. Shaft spins easily.
    I removed all the wires from the motor and then plugged them back in
    Which leads (wire colors) can I check with my meter to make sure that it is getting the proper voltage?
    Any other ideas?
    thanks
    Rob
    Oct 2014
    Sacramento, CA
    70
    Re: Booster Pump humming
    More then likely its shot probably just need a new motor you took all the proper steps so far. I would just by a new pb460 on amazon I think they are only about 250.00 free shipping
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
