Thread: Limestone Fountain. Please help with Algae!!!!
    Oct 2016
    Orange County, CA
    1
    Hi, i have a limestone fountain and i'm having a hard to preventing algae growth. Fountain was built about 4 months ago. First time i had algae i used Kem-Tek Algaecide and it killed the algae within 24 hours. Ive been adding about 2 ounces per week and it is no longer effective. My gardener drains the fountain once a month but algae keeps growing every two weeks.
    I've contacted limestone tile manufacturers and pool guys and none seem to be familiar with limestone. They all recommended i don't use chlorine long term to keep algae from growing. Should i be concerned about using chlorine or bromine to shock kill the algae? Should i be concerned using it long term on limestone?
    Any help on how to kill the algae and upkeep my fountain long term would be greatly appreciated!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,078
    Re: Limestone Fountain. Please help with Algae!!!!
    Welcome to TFP!
    Is this a decorative fountain? No people in it? Lots of people have pools with limestone and use chlorine. I would use chlorine to prevent algae. You can float a trichlor puck in a puck floater or add bleach regularly to keep the chlorine level up around 5 ppm. A cheap chlorine test will let you test it to make sure it doesn't drop to 0.
    30,133
    + 1 what pooldv said. Keep your FC around 5 ppm with a chlorine tester (You have to test resularly) and you will nor have algae.
