Thread: Closing pool ph is 7.2-7.3
    Jun 2016
    New England
    98
    I already started to blow out lines. This has been an on going processes as many things didn't work.
    Ended up going the cyclone route after testing compressor and shop vac and blow out plugs.
    This has been done over two weeks and I've been maintaining high FC so it will be ready.
    I already started blowing out lines today but the ph is a little low. Is there a good way to bring it up to 7.5 without requiring my to turn on the filter again? I can reconnect the basket cap and refill the system if I need to but if there is a quicker way so I can just wrap this up today would be great.
    I've been monitoring ph over the two weeks we have been trying to close but it has fluctuated a lot as I have added a lot of 12.5 chlorine at one go.
    I need about .3 ph for about 35-40k gallons.
    Is 7.2-7.3 an issue for closing? I focus on 7.5 during the season.
    Christopher
    21' x 43' IG 40K Gallon vinyl and concrete pool; liner: 2016; Hayward DE7220 filter; Maytronics M400; TFT-100; Speed-Stir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Closing pool ph is 7.2-7.3
    Leave it where it is and don't worry. It is absolutely fine where it is.
    Essential Links:
    domct203's Avatar
    Jun 2015
    CT
    3,425
    Quote Originally Posted by Patrick_B View Post
    +1
    Put her to bed for the winter, you should be fine.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,195
    Can you tell me where you hooked up the Cyclone? Of course, I am assuming you used a 1'5" hose.
    I have used the Cyclone to unclog my central vacuuming system (low pressure high volume) and to unclog a laundry room sink for a friend. No good to blow out sprinkler lines (only air compressor works best) as there is too much resistance in the sprinkler heads.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
