Thread: PoolMath suggests half the required HCl
    Sep 2016
    Melbourne, Australia
    29
    PoolMath has worked well for me for all adjustments other than pH. I find that I need about double the suggested HCl to lower the pH by a certain amount than what PoolMath suggests.
    My chemistry is as follows:
    FC 6
    CC 0
    pH 7.6
    TA 70
    CH 410
    CYA 80
    Na 4400
    Temp 18 degrees C
    My only idea is that there is a buffer in the pool that I am not aware of. I have not added borates to the pool, and I doubt the previous owner would have. Do you have any alternative explanations or suggestions of the buffer?
    ​GeoQuack
    Melbourne, Australia. Plaster pool 44,000 Litre (11,625 US gallons), 2 HP 1 speed pump, Zodiac LM3-40 SWG, Zodiac CX20 robotic cleaner, PoolSkim, solar heating, sand filter, clearchoicelabs.com.au test kit (TF100 or taylors not available in Australia), big eucalypt that drops infinate leaves, gum nuts, pollen and sticks into pool
    JoyfulNoise's Avatar
    May 2015
    13,412
    Re: PoolMath suggests half the required HCl
    Are you sure your MA is 31.45% (20 Baume)? Many places sell pool acid as well as contractor MA that's 15% because it does not fume.
    Matt
    Sep 2016
    29
    Yes, it is 32%. It certainly does fume.
    Mar 2015
    Georgia
    157
    Some types of Dichlor shock contain borates as an additive. Not sure what kind is available in Australia but maybe they used that. Try a borate test.
    16k AG Vinyl Sand Filter
    Sep 2016
    29
    Will try a borate test, just have to find a shop that sells them.
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    358
    Quote Originally Posted by GeoQuack View Post
    Don't bother looking in the shops, online is your best bet.
    Our acid is is definatly full strength. I've never aclually tested my pH after the recommended PoolMath dose but I recently had a 50% difference between the acid demand test and PoolMath. You might be on to something.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
