Thread: Backwashed drained pool a bit
    Oct 2016
    Phoenix
    2
    Hi, I am new here and also a new pool owner. I went out when I got home from work to backwash a little bit in prep for some algae treatment. My son came out and I shut it down and went inside. I forgot to close the backwash valve. I have a DE filter. I came out about 3 hours later to work on the pool again and had a heart attack as the yard is flooded and the water line is about 1.5' below the skimmer.
    How bad does this mess things up? If anything? I've read it can tear the grids and also break the pump?
    Any guidance is appreciated! Thank you
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Re: Backwashed drained pool a bit
    Welcome to TFP!
    Not sure about tearing the grids. It can damage the pump if it runs dry too long. Best thing to do is fill it back up and give it a test run. Good luck!
    Oct 2016
    Phoenix
    2
    Hi! Sorry for the late reply. Forgot I had posted. Pump seems to be working just fine still. I just cannot keep chlorine in the pool. I'm adding tons daily and it seems to be gone by the time I'm home from work. I think I just need to keep brushing and adding it until it can hold for longer than a day?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    31,572
    Do you have a test kit? If not please think about getting one. It really sounds like you need to do a SLAM
    Pool School - SLAM - Shock Level And Maintain
    Your pool will start going green if you do not get the algae out. It is trying to tell you it is there by eating your FC.
    Kim
    30,496
    Yep, like Kim said, you need to test your water and stop guessing at what might be. We can help but we need test results to understand the condition of your water.
