Thread: Noob Intro
    Oct 2016
    Austin TX
    6
    Noob Intro
    Hi all. Long time reader, first time poster.
    FC 5.0 avg
    CC 0
    pH 7.8
    TA 80
    CH 400
    CYA 60
    I purchased a home with a pool in spring 2016. My CYA (260) and chlorine (10+) were probably due to the previous owner/pool services chlorinator settings. A local company provided a pool school before I found TFP. I have drained half the pool twice to reduce the CYA and turned off the chlorinator, using bleach exclusively instead. The water seems crystal clear.
    My test results are pretty consistent with my neighborhood bi-weekly Leslies tests; I get my chlorine and acid there too since it's close and competitive with big-box stores.
    Thanks to TFP for guiding this noob.
    Steve
    First time pool owner April 2016 | 11,300 gallons IG Plaster with Water Fall | Tagelus TA 50 Sand filter | Jandy SHPF Pump | Polaris PB4-60 Booster Pump | Polaris 280 Cleaner | TF-100 Test Kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,559
    Re: Noob Intro
    Hi Steve,
    Welcome to TFP, a great place to be.
    Your numbers looks pretty good to me, but please keep in mind with a CYA of 60 the very minimum for your FC should be 5, you really should be shooting for around 7 or 8. See this chart... Chlorine CYA Chart
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,285
    Re: Noob Intro
    Welcome to TFP! Good to have you here
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Oct 2016
    Austin TX
    6
    Re: Noob Intro
    I figured out how to upload an image of the pool:
    Jun 2014
    15,284
    Re: Noob Intro
    Looks good. Enjoy another fantastic day of TX sunshine.
    needsajet's Avatar
    Jan 2016
    4,285
    Re: Noob Intro
    Looks great
    I know where I would do a bomb (cannonball)
