Thread: Decided to keep pool open my first season in new house
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    The previous owners didn't even have a cover for the pool and they always kept it open. We are going to attempt to do the same. We do a lot of outdoor entertaining in this backyard and the pool is the centerpoint so having a cover over it would hurt the ambiance a little. Anyway, in lieu of going and buying a cover, we're just gonna see how it goes. We have a couple of trees so I'm already making leaf clean up in the pool part of my daily routine.
    Any tips from anyone? I'm expecting the chlorine demand to go way down (it already has) and hopefully as it gets colder and all the leaves are off the trees I can lower my pump run time. As far as TFPC guidelines, does everyone still recommend testing and adding sodium hypo everyday? Or will the chlorine demand go down so much that this can be done on a less frequent basis?
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Decided to keep pool open my first season in new house
    I stay open year round.
    Yes the chlorine demand goes way down, part of that is when the water gets below 60 degrees algae pretty much can't grow.
    Also the sun is much less direct in the winter, thus keeping the UV consumption way down.
    I just switched to "winter mode" yesterday as I noticed the water temp is now 58.
    In winter mode, I turn off the pump at the breaker and only run it on saturday or sunday for a few hours while the suction
    auto cleaner cleans the floor. I only need to test once per week and I may or may not need to add bleach to
    keep the chlorine at a minimum of 4ppm. For my CYA of 50 I have to maintain between 4-8.
    During the winter I don't cover it. But I do check daily for debris floating. Yesterday there were a ton of red pine needles
    floating so I netted those out.
    This will by my third year doing it this way. It has worked perfectly well, maintaining clear water over the winter.
    Dolphin E10 Cleaning Robot.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    BigDog43 - I do suggest that you keep the pump capable of operating. This is just in case we get a few cold nights in a row. You just run the pump during the evening and that will stop stuff from freezing solid.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    Thanks for the input. I'll play it by ear on how much I can get the pump run time time. Seems the last few winters around these parts didn't get very cold so I think my overall risk of things freezing up is low, getting down in the high 20s is about as cold as it gets....but I hear ya loud and clear. Thanks!
    Memphis, TN.
    Taylor K-2006
