Thread: Testing new pump and filter
    domct203's Avatar
    Jun 2015
    CT
    3,515
    I've recently took advantage of the crazy price at Amazon and bought a new 1.5HP Hayward pump & 21" sandfilter. Next spring I will need to create a proper equipment pad for this much larger system.
    I would like to at least try the filter and pump this weekend before I close the pool to make sure everything works and there are no defects. I do not want to add the 200lbs of sand as I will need to move this filter to pour a slab in the spring, then move it back onto the pad for opening.
    Are there any concerns with running the sandfilter empty? I know that centrifugal pumps work easier if there is back pressure on the pressure side, I planned to close the return valves a bit to simulate the backpressure experienced with a sand-filled filter.
    I only plan to run for 5-10 minutes this way.
    Anything I should be concerned with? Will this damage anything?
    Thanks.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    domct203's Avatar
    Jun 2015
    CT
    3,515
    Re: Testing new pump and filter
    Dom - TFP Guide
    Mod Squad pooldv's Avatar
    DFW, TX
    24,283
    You are on the unanswered threads list!
    I don't know anything about running a sand filter with no media in it. The only thing I can think of is that it might blow the laterals off and damage them. So, maybe enough sand in the bottom to keep it all together?
    domct203's Avatar
    Jun 2015
    CT
    3,515
    Quote Originally Posted by pooldv View Post
    I was worried about the laterals as well. I am thinking of leaving the entire stand pipe/laterals assembly out. I'll manually fill the filter with water too.
    Dom - TFP Guide
    DFW, TX
    24,283
    That sounds good. Just to test the valve and make sure the housing doesn't leak.
