Thread: Recommendation for automation?
    Oct 2014
    Leesville, SC
    6
    I have an in-ground pool with Pentair Intellichlor IC40, IntelliFlo VSP pump, and Polaris Sport 280 pressure side cleaner with Polaric PB4-60 booster pump. I have the pump hardwired into the 240V on the sub-panel with an operating schedule set into the pump (which I adjust for different seasons). And I have the IntelliChlor and the Polaris cleaner on an Intermatic p1353 timer.
    I live in central SC and the pool stays open all year.
    Until this summer all this equipment was on a small covered back porch of a small outbuilding -- thee sides open the outside. This worked well as I used the freeze protection circuit built into the pump to turn it on if the temperature dropped to near freezing.
    This summer I renovated that building, and installed a full bath. I moved the house well reservoir to this back porch and installed an electric water heater on the porch for the bath. And we closed in and insulated the porch. Better for the water heater, and much better protection for the pool equipment. Unfortauntely now the temp is unlikely to drop below 50 degrees in that space, and so the pump freeze protection circuit is pretty much useless.
    I think I have two options:
    1) Move the pump back onto the Intermatic timer (which also has a freeze probe), which I believe eliminates the use of ability to define an operating schedule in the pump, and the on-off control for the pump(and only on-off) is now controlled by the timer. I think this changes the pump back to essentially a single speed pump, except I get to choose the speed. (As I understand it, the pump will return to its previous setting, when powered back on by the timer.) Is all this correct?
    2) Install some more automation -- likely something from the Pentair line. Essentially I'd be installing this to be able to connect an air temperature sensor with a wire to reach the outside and a water temp sensor. Which automation package would you recommend in this solution?
    I already have a electrical sub-panel in this space for the pool equipment and HW heater circuits.
    And I don't have any more automations on the pool (no lights, no spa, etc.) and am not really planning to expand in this area.
    Any thoughts/recommendations for a solution?
    Thanks in advance
    Michael
    Pool: 29.5K IG vinyl, Hayward Pro Series High Rate Sand filter #S220T, Pentair IntelliFlo VSP pump, IntelliChlor IC40 salt chlorine generator, Polaris Sport 280 pressure cleaner w/new Polaris PB4-60 Booster Pump, 1 Intermatic p1353 Timer (used only for IntelliChlor and Polaris Sport cleaner).
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    6,949
    Re: Recommendation for automation?
    Mike,
    The simplest solution would be to just have the pump run 24/7, at 900 RPM, during the periods of time when you might expect a freeze. My guess is that would cost you about $10 bucks to running continuously for a month.
    Since the Intelliflo is controlled by a serial cable, I'm not sure what other external option there would be except for installing an EasyTouch system, which seems like serious overkill in this case and would cost $1,000.
    Sep 2016
    Escondido/CA
    636
    Or move the existing sensor to outside the building.
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Jul 2014
    Bedford, TX
    6,949
    Quote Originally Posted by xyz View Post
    The sensor is inside the pump electronics... so, not really an easy option.
    Sep 2016
    Escondido/CA
    636
    Quote Originally Posted by Jimrahbe View Post
    Hmm ok, you -may- be in luck. I'm going to assume the control board for a ET4 is the same as an ET8. I have the 8, and it has two locations, marked on the board, for both air and water sensors. Simple screw terminals, easy to install. If this is the case for you, you can buy a pentair sensor, and attach it to this connection point, and then run the sensor outdoors.
    Im not sure which sensor triggers the freeze mode, but either way, hook them up, and you should be all set.
    Apr 2015
    tucson, arizona
    1,047
    http://www.pentairpool.com/pdfs/easytouchpl4DS.pdf, This is Pentair's entry level automation. You would go with the PL4, since you have no spa. The freeze protection in the Intelliflo pump is for the pump's drive not to protect your plumbing.
