Thread: algae
    im a newbie and im begining to see either real dark green or black stuff on my inwall skimmer like ring around the skimmer. is this algae?i also see some white floating things?? all numbers check out i put in some more anti algae stuff. its an ag pool 24 ft round.
    Above ground 33 ft round 52 in. high
    Approx. 25000 gallons
    Hayward Dreamline Sand filter holds 250lbs sand
    Hayward CL-200 chlorinator
    Hayward 1.5 hp 67 GPM pump
    Re: algae
    Hi Mike!
    I can't answer your question, but I know the smart folks around here will want some more information from you before they can, either. Read this and post back your pool and chemistry details.
    IG ~15,000 Gallon Plaster Pool with Attached Spa
    Hayward SwimClear C4025 - 150GPM, Cartridge
    2hp Pump 1.1 Service Rating
    Direct sunlight most of the day
