Thread: Water temp at 60, but closing this weekend
    Her pool boy's Avatar
    May 2016
    St Catharines, Ontario, Canada
    So my water temp finally hit 60 degrees today but I will not be closing the pool until Sunday...I hope. My question is, do I have to maintain a FC of 3 to 5 still, or can I let the FC drift below until I am ready to close? My CYA is 40 and my FC is presently at 3 ppm. Any advice would be much appreciated.S
    16' x 50' - 95K L (25000 gallon) I.G. Vinyl liner 12.5 Liquid Chlorine
    Wicor Pantera P24 Sand Filter Pentair Superflo Variable Speed Pump
    Zodiac 3510WD Robotic Cleaner Raypak R336A Heater. ​Taylor K2006c test kit
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    Re: Water temp at 60, but closing this weekend
    If you are adding PolyQuat 60 Algaecide, you should be fine. Remember to open up early in the spring. I doubt you will have any problems.
    If you want to have extra protection, it is best to bring the level up to around 5-7 ppm and the Algaecide. This is one time during the year that the PolyQuat is recommended.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Aug 2014
    Northern IL
    Many of us do a quick raise to slam level and do an OCLT to make sure all is good. See here: Pool School - Closing an In Ground Pool
