Thread: Post Hurricane clean-up
    Jul 2014
    Hope Mills, NC
    561
    After 15" of rain and a hay-bale size pile of leaves in the pool, I finally got the debris out from around the pump and started cleaning the pool.
    Scooped as many leaves out as possible and vacuumed the bottom quite clean. I was pretty happy to see the bottom!
    I did a quick test just to see how it looked and the pH was 7.2 and the FC was 6.0. Salt is showing 3100, but I know that will take 24 hours to settle, I'm betting on 2 or 3 bags of salt when I get home after work. Will do a full test after work and I think the CYA will be way down as well as salt.
    The solar cover got a few tears when it tried to carry away the roller, good thing the roller blew into the pool and anchored itself pretty well.
    Lost one tree and have several that will need to come down, as they are leaning over my fence and the root balls pulled out of the ground. I know the next heavy wind will knock them through the fence.
    Hurricanes are no joke...
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Re: Post Hurricane clean-up
    No doubt about that! Glad you're in pretty good shape.
