Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: How much did you spend on pool maintenance this summer?
    May 2016
    Lynchburg, VA
    49
    I was inspired by another thread to post this. I think it would be good to share what we spent on pool maintenance this year to show folks how cheap the TFPC method is. Here's a breakdown for me:
    Bleach, Borax, Baking Soda $85.79
    First Test Kit (Taylor K-2006) $64.99
    Reagent Refills $65.47
    Pump maintenance and parts $33.87
    Polyquat for closing $21.85
    TOTAL $271.97
    I had some extra expenses this year that I don't think I'll have next year. For example, I won't need to buy a whole new test kit next year (this is my first year using one), and hopefully I won't have as much trouble with my pump next year. I'm very happy with this. The previous owner of my home told me he spent on average $500 a year on chemicals alone.
    EDIT: I should note I had about 8 pounds of Cal-Hypo shock left over from the previous owner, which came in very handy for a SLAM at the beginning of the summer and a couple other times when I was going away for the weekend. I think that would have cost me about 40 dollars if I'd bought it myself, though I would have used liquid chlorine instead if I didn't have that.
    12250 gallons | IG | Vinyl liner | Sand Filter | Emerson 1081 Pump EUST1102 | Hayward Pro Series High Rate Sand Filter Model #S166T | Pool <10 yrs. old | Taylor K-2006 test kit | SharkVac automatic pool cleaner
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,200
    Re: How much did you spend on pool maintenance this summer?
    I spent $ 145 so far this year...been keeping track of everything since january chemical wise.
    The electricity for the pump is $ 10 per month = $ 50
    And i spent about $ 30 a month for gas heating may-sept = $ 150
    So $ 345 total expenditure this year to have the pool. Not bad!
    Dolphin E10 Cleaning Robot.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,189
    About $400,000.00
    Jun 2013
    South Florida
    118
    A bag of salt - $6
    A two pack of muriatic acid - $11
    Two replacement hose sections for the suction cleaner - $28
    Plus whatever it costs to run the pump.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,970
    I think about 26$ on CYA. about 18$ on salt. My VS pump only uses 180 Watts which comes out to be about 12 a month on electricy. My pH is rock solid so I didnt use any MA. Thats about it for me. ..oh! and I did buy a new skimmer net. 22$.
    Divin Dave,
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Let's see. This was the first year owning a pool so this will be interesting.
    After TFP:
    • Chlorine - $40 * 2 = $80
    • Test Kit & Reagents = $184 <-- overbought reagents. Learning experience
    • Baking Soda = $10
    Total Cost for four months = $270
    Before TFP:
    • Pool Shock = $63*2 = $126
    • Algaecide = $24*2 = $48
    • Chlorine Tabs = $130
    • Cyanuric Acid = $80
    • Baking Soda = $20
    Total Cost for two months = $404 <-- those were all the receipts I could find
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
    Surf_ox's Avatar
    Aug 2016
    Cypress, TX
    40
    Quote Originally Posted by PoolguyinCT View Post
    About $400,000.00
    We need pics of that pool.
    13K; IG Pebble sheen [4,5,4] with sun deck; 2hp pentair cleaning the water through a Clean and Clear Plus; 2hp pentair flowing the natural rock waterfall and 3/4 hp powering the 2011 Pentair legend (AKA "THE DUDE")
    PoolingAround's Avatar
    May 2016
    Katy, Texas
    203
    New pool so still getting things dialed in. My pump electricity costs and muriatic acid fills drive the cost up. No more adding bleach so that expense is gone. Here is the breakdown from mid July till now.
    Initial bleach months = $80
    Muriatic Acid = $120
    Electric Cost = $100 (roughly) x 4 months = $400
    Excess water = $20 x 4 = $80
    Test Kit = $80
    Total cost for 4 months = $760
    18k gallon, 20x32, salt IC20, gunite with quartz finish, raised spa with overflow, flagstone coping, moss rock waterfall, Pentair Intelliflo variable speed pump, Pentair Racer, Pentair pool pump, cartridge filter, heater, etc., acid dispenser.
    TF-100 kit for sparkling clean water.
    setsailsoon's Avatar
    Oct 2015
    Stuart/FL
    457
    Here are my monthly costs:
    Chemicals:
    21/2 gal bleach per month $1.45x2.5 = $3.63 ... say $4
    1 gal MA about $6.50
    Reagents about $2
    Total $12.50
    Fun Support:
    Margarita Mix
    Tequella
    Other Beverages
    Plastic Disposable Beverage Glasses
    Replacement pool toys for grand kids
    Total mega $$$$
    Fun Had:
    ... priceless!
    -Chris-
    2013 In-ground plaster/pebble, screen enclosed, 12000 gal w/ Jandy 2 speed 1 HP pump, Jandy CS 200 cartridge filter, 800 gal spa w/ 1.5 HP booster pump, Solar heater, 2 LED lights in pool 1 light in spa, TF-100 test kit, The PoolCleaner Next Generation, Jandy RS-12 Automation system with iAqualink 2.0 control, Separate Hayward/Goldline Solar control
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Setsail,
    I guess I do not understand. How did you get by the whole summer on 2.5 gallons of chlorine? Also living in Florida, I could not get by on 2.5 gallons of chlorine a week.
    pabeader's Avatar
    May 2015
    Dallas Ga
    4,072
    He listed it as monthly...
    Bob - Palm Beach by San Juan Pools. approx 5000 gals., Pentair 320 cartridge filter (all new guts installed by me), Goldline SWG, 'New to me' Kreepy Krauly Sand Shark, Intermec 104 Timer Test kit: TF-100 w/Speed Stir
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    pabeader,
    Even a month is remarkable. I wish I could get that kind of use out of our chlorine. I need to know the secret of only losing 14 FC a month, instead of my 2-4 FC a day. /nod
    JoyfulNoise's Avatar
    May 2015
    12,905
    Quote Originally Posted by Holydoc View Post
    pabeader,
    Put a bubble cover on your pool. A covered pool has very low FC loss....however, your cost in bags of ice to keep the water from boiling may go up....
    Matt
    Jul 2014
    Connecticut
    1,189
    Quote Originally Posted by Surf_ox View Post
    LOL - it's many pools, I own a pool company.
    Ray
    pabeader's Avatar
    May 2015
    Dallas Ga
    4,072
    That would be about 4000 TFPC maintained pools!
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Hmm... I could cut up carrots, potatoes, and tomatoes into the pool for soup... kill two birds with one stone!
    Oct 2015
    Stuart/FL
    457
    Setsail,
    Usage is avg per month. Peak was a little higher. I guess the reasons are totally enclosed pool gets less sun, about 35% smaller than your pool. 9 hr per day pump time? Cl is 10.5% liquid from Leslie's. My acid use is pretty high at 1 gal per month...I'll double check to see if I missed a purchase but I'm pretty sure I didn't.
    -Chris-
    Surf_ox's Avatar
    Aug 2016
    Cypress, TX
    40
    Ray
    Awww was hoping for a 100acre resort pool with all the goodies.
    pabeader's Avatar
    May 2015
    Dallas Ga
    4,072
    Enclosed pool makes a big difference.
  20. Back To Top    #20
    Jul 2014
    Connecticut
    1,189
    So was I
