Thread: Hayward Max-Flo VS - Err01 - Undervoltage on DC-Link
    Mar 2015
    Orlando, FL
    7
    I've had my pump setup for a little over a year now with no issues. We recently had a hurricane move through (Matthew) and I lost power for about a day. Ever since the power was restored, My pump is failing upon startup in the morning with the ERR01 error code. To get the pump going, I just press the "run" button and it starts doing it's thing.
    I'm wondering if maybe the power outage somehow damaged the pump? Pump runs fine once I press the button, but I don't want to have to manually start it every day (and it would surely be an issue if I was away).
    I do have a timer box that feeds the pump (set to turn on and off). I left this in place due to the fact that if a power surge caused the pump to error, it would stay in that state until it was manually corrected, OR the power was cycled. (this would be in issue if it had this situation while I was away for a week). the timer box assures that every day the power is reset.
    SO, has anyone else had a similar issue that they were able to resolve?
    Thanks!
    14,800 Gal, IG Plaster, 100 Sq ft Cartridge filter, 1hp pump, rebuild 4/1/2015, Taylor test kit, Zodiac MX-8 vac
    domct203's Avatar
    Jun 2015
    CT
    3,429
    Re: Hayward Max-Flo VS - Err01 - Undervoltage on DC-Link
    Sorry to see that there have been no replies.
    Here's a friendly bump!
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
