Thread: Hayward Colorlogic 320's vs. Sr Smith Treo's
    Sep 2016
    Hubert
    2
    Looking to replace 3 small fiber optic lights with LED’s.
    Moved into a house with pool a year ago, only thing I know about the pool (16 x 40) is that liner was replaced 3 years ago. Problem is that old lights are covered by vinyl liner (they must not have been working) with a ring 3.5” outer diameter and 2” inner diameter. So my plan was to drain pool 10 inches, carefully cut liner so I can pull lights out and fish new one’s back in. I think I can take it from there.
    My first choice are the Hayward 320 color logics (networked). They seem brighter (23 watts), have more colors and light shows and looks like these lights don’t protrude into pool. Hayward customer support is pretty quick to say they will not work unless niche is exactly 1.5” (looks like I have 2” but might be 1.5” will not be able to tell until draining pool and cut liner covering old light) and 8” behind light (I think I have that). Seems like these lights are more for new construction.
    Second choice, Sr. Smith’s Treo (networked … don’t seem as bright (5 watts) , not as many colors/shows and the protrude into pool been told these light should lights will work. These lights would be a little more economical.
    If anyone is familiar, or has purchased/ installed either of these lights I would really appreciate hearing from you. Any input/advice that would help me with this project would also be appreciated.
    Thanks
    Tim
    Swansboro NC
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,628
    Re: Hayward Colorlogic 320's vs. Sr Smith Treo's
    Welcome to TFP trross64
    '70s IG Vinyl 32K gal, Lazy L, Hayward SuperPump 1.5hp 120V, S240 Sand Filter W/DE
    Solar Blanket, Well Water, Borax Added, TF-100 tester. ?° too cold
    1979, 275gal Conway Emerald Spa P-100-2, ES-2 Spa Pack, bromine floater, indoor
    TF-100 test kit -> TFTestkits.net
