Thread: Pentair ultratemp not heating
    Nabortz's Avatar
    Aug 2016
    Jacksonville, fl
    8
    New pool owner 2 months now. Pentair ultratemp 120 electric is running but not heating or heating very slowly. We're in Jacksonville FL. Had to bail because of Hurricane Mathew. I turned everything thing off. We did lose power but didn't get hit bad at all I have an enclosure and received zero debris in the pool.
    We were able to come back yesterday I turned on all equipment and everything is good to go except the heater. It appears as though it's working, cool/cold air coming out of the top, condenser clicks on, condensation on coming out the drain. Pool temp will not go above 81.
    The only thing I can see different with the pool is the water level is really high.
    Any suggestions?
    Nabs
    In-ground, Gunite, 16K Gal, 30'x15' Rectangle w/
    10'x7' Tanning Ledge cutout
    Pentair Equip
    CMP Brilliant Wonders Waterfall
    Mod Squad pooldv's Avatar
    DFW, TX
    18,414
    Re: Pentair ultratemp not heating
    Has it been serviced by an HVAC company in the last year or two? Freon needs to be checked and the compressor oil too. It is the same heat pump type of system as the HVAC in a house and should receive an annual check up.
    Nabortz's Avatar
    Aug 2016
    Jacksonville, fl
    8
    It's 2 months old all new Pentair equipment. Pump is running just fine.
    Nabs
    Pentair Equip
