Results 1 to 7 of 7
Thread: Pool Re-plaster 101
    Pool Re-plaster 101
    Folks,
    Do we have any 101 documentation re: pool replastering? I think she's starting to go. It's 16 years old,so no complaints. What I'm seeing are very small pin head to nail head sized pock marks with what looks very much like the grey metal shell showing through. Not many, probably half a dozen or so. I'd like to keep it going for as long as possible but it seems like it's inevitable and I just want to educate myself as to the process and most importantly the 'pitfalls', (no pun intended.)
    Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,259
    Re: Pool Re-plaster 101
    Plaster doesn't need to be replaced until it doesn't hold water anymore. Eventually it will leak enough that it has to be done. Everything else is cosmetic and personal preference. Gray metal shell? Most plaster pools are plaster over concrete. Are you sure you have plaster over a metal shell?
    Here are a couple of technical articles on plastering a pool.
    Ten Guidelines for Quality Pool Plaster
    Diagnosing Pool Plaster Problems
    Quote Originally Posted by pooldv View Post
    Thanks. I'll take a look. Yes, I meant concrete. Metallic looking would have been a better description. So, the fact that the plaster is going in small spots wouldn't cause damage to the concrete base?
    Thanks
    Apr 2013
    Sacramento, CA
    2,769
    Generally the degradation of the plaster has little if any effect on the shell. If the shell has problems like exposed rebar then that's a differ problem.
    Quote Originally Posted by iceflow View Post
    Thanks
    It's clearly thinning but you'll know when you need to replaster.Ours started coming off in flakes and chunks before our replaster last year.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,628
    Iceflow, Can you please add you pool and equipment info to your signature as outlined here - - > Pool School - Getting Started
    '70s IG Vinyl 32K gal, Lazy L, Hayward SuperPump 1.5hp 120V, S240 Sand Filter W/DE
    Solar Blanket, Well Water, Borax Added, TF-100 tester. ? too cold
    1979, 275gal Conway Emerald Spa P-100-2, ES-2 Spa Pack, bromine floater, indoor
    TF-100 test kit -> TFTestkits.net
    Thank you all for the information.
    Thanks
    Plaster In Ground, with Waterfall Spa. Raypak Heater, Nautilus DE Filter DNS48. Built about 2000.
