Thread: Connect to ISC-100
    Connect to ISC-100
    I'm finishing my wiring to a 2014 Sundance Cameo and while connecting the LFNC-B conduit to the spa panel, I found a ribbon cable unplugged at the bottom of the equipment bay. This cable is labeled 'Connect to ISC-100'.
    A quick Google search (no hits searching this forum) leads me to believe this is for a stereo which I do not have. Would someone kindly confirm if I have this right. Thank you.
    domct203's Avatar
    Jun 2015
    CT
    3,425
    Re: Connect to ISC-100
    I'm not sure if you've worked this out, but here's a friendly bump to your thread to see if we can get you an answer.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
