Thread: 115v 2-speed pump options
    Oct 2015
    Safety Harbor, FL
    3
    I need to replace my old pump (1HP Pump - EUSQ1102 / Sta-rite P2R), and I'd really like to upgrade to a 2-speed pump. However, I'm having a tough time finding many 115v options. Given my current wiring and timer setup, I'd really like to avoid switching over to a 230v setup.
    Are there any options other than the Pentair WFDS-24 / WFDS-3 to consider? Our solar setup is on a 1-story roof. So, I think the Pentair would work well. I just want to make sure I'm not overlooking a less expensive option that would also work well.
    Also, can the Pentair WFDS-24 pump speed be controlled externally. I'd be trying to control it from either the solar controller or an Intermatic PE653.
    14000 Gal In ground, Cartridge filter (PFAB80), 1HP Pump (EUSQ1102 / Sta-rite P2R), Solar heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Re: 115v 2-speed pump options
    Pentair makes a 3/4hp Superflo pump in 2 speed 115v, 341111. They also make the 1-1/2hp variable speed pump that operates on 115v, 342001.
    Oct 2015
    Safety Harbor, FL
    3
    Quote Originally Posted by pooldv View Post
    Thanks! The price difference for the variable speed pump seems worth it (an extra $150 over the 2 speed options). I think it will also integrate with my DIY automation setup better as well.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    I replaced my 1hp with the Pentair VS (342001) and really like it. For your DIY automation you can program 3 pump speeds plus a quick clean speed via the pump menu and select the speed for the pump to run from the provided digital input (does require you purchase cable).
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,602
    Welcome to TFP 4x400m
    '70s IG Vinyl 32K gal, Lazy L, Hayward SuperPump 1.5hp 120V, S240 Sand Filter W/DE
    Solar Blanket, Well Water, Borax Added, TF-100 tester. ? too cold
    1979, 275gal Conway Emerald Spa P-100-2, ES-2 Spa Pack, bromine floater, indoor
    TF-100, Best test kit - TFTestkits.net
