Thread: Still struggling in Southwest Arizona
    Oct 2015
    Az
    12
    Deleted
    Apr 2013
    Sacramento, CA
    2,769
    Re: Still struggling in Southwest Arizona
    All chip outs look ugly.
    You probably want to remove that rebar, do some surgery. Shotcrete is not just sprayed over the pool in layers, it doesn't work that way.
    On the whole it doesn't matter what we think it matters what your finish installer thinks and you haven't told us that. So have your finish contractor look at it and opine on the work.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    +1 to finding out what the people installing the plaster think. It doesn't look all that bad from here.
    Aug 2007
    near the swamp
    806
    Your chipping looks normal, sorta like Mayan hieroglyphics.
    Rebar needs cutout and epoxied. Plaster needs that rough look to adhere to.
