Results 1 to 9 of 9
Thread: Baquacil vs polyquat
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    108
    Crud! I realize when I went to Leslies I bought Baquacil algaecide and not polyquat 60.
    For closing I was going to add the max dose of algaecide. Think I'm ok to use this baquacil rather than polyquat? Or is the same thing?
    John
    27,000 gal concrete rectangle, built Oct '15, DE filter, Jandy PHPM 1.5 HP, Hayward HP21104T heat pump, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Re: Baquacil vs polyquat
    No, not the same thing. Take it back and get the polyquat 60.
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    108
    Quote Originally Posted by pooldv View Post
    Just found the receipt! Thanks ill go tomorrow.
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    108
    Quote Originally Posted by JohnA902 View Post
    Crud again! Receipt says they won't take chemicals back after 14 days. Fun. So now I have this baquacil algaecide.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    I would take it back as you are making an exchange. I suspect they would want to keep you as a customer. Suspect that is on receipt so people don't buy a "summer's" worth of chemicals when on sale, then try to return the unused at the end of the season.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    6,674
    By any chance is it the Baquacil Performance algicide???
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    108
    Quote Originally Posted by Leebo View Post
    It's just a little blue quart bottle that says "step 3"
    It has two main ingredients. Both benzyl ammonium chlorides.
    I ordered the right stuff on Amazon. It will be here Wed. Pipes get blown out on Thurs.
    JoyfulNoise's Avatar
    May 2015
    11,842
    Standard Baquacil algaecide is usually a mixture of linear quat algaecides. You do not want to use it in your pool as it will be oxidized by chlorine and cause foaming.
    Return it if you can or dispose of it. It's no use to your pool.
    Matt
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    108
    Update - they took it back no problem. Whew.
    Side note. The Leslies algaecide is the same ingredient as the poly quat that I ordered on Amazon.
