Thread: closed the pool for the first time..no extra equipment needed
    Jan 2016
    New York
    3
    figured out a cheap way to drain my pool...I just turned my filter to WASTE...
    took my pool vacuum hose, wrapped plumber's tape around it to create a seal..stick one end into my skimmer ...the other end into the pool...drained like 1 feet of water below the skimmer line...enough to go below the returns..
    checked to make sure my sewage pipes aren't overflowing...worked like a charm...
    and I didn't even need a bilge pump to pump out the skimmer when i blew out the lines..sticked the same pool vacuum hose in there and direct the water back to the pool...works better than a bilge pump....plugged it and stuff the skimmer with short pieces of pool noodles...no gizmo needed...
    have an air compressor already...blew out all the lines
    did not have to buy anything except new plugs, one pool noodle, eyeball removal tool and pool shock/algaecide...cost me $50...it will cost me $10 next year...i still have 1/2 bottle of algaecide
    my pool guy said it's too expensive to do it myself ...proved him wrong
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    29,289
    Re: closed the pool for the first time..no extra equipment needed
    Nice job! Just shows what you can do when you put your mind to it and are willing to try!
    NICE job!!
    Kim
    dw9000's Avatar
    Aug 2014
    NW Ohio
    180
    I closed mine today,, talk about no extra equipment - I didn't even use a vac,, I just took some deep breaths and blew out the drain & return lines. My wife commented that I had rosey red cheeks.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,144
    That's not what your pool guy meant..
