Results 1 to 7 of 7
Thread: Started the close but heavy rain came in
    Aug 2016
    New Haven CT
    62
    Hopefully someone will have some insight on this question. I started to close the pool, got it balanced, cleaned, and put in the winter chemicals to cycle a few hours. Pulled the rails and was about to start draining the level below the skimmer then it started to rain and I called it a day. Today it's pouring again so my question is with the winterizing chemicals. I have the filter running, does it matter or should I shut it down till next weekend when I can get back to closing or will have to use more?
    Thanks
    Gary
    Gary
    New Haven, CT
    16 x 32 x 8 in-ground vinyl , sand filter
    22,000 gallons
    Leslie test kit, TF100 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,274
    Re: Started the close but heavy rain came in
    Please describe your "winterizing chemicals."
    Aug 2016
    New Haven CT
    62
    Hi woody
    I used :
    1 gallon Diamond Clear -which is described as Cationic Polyeric Floc
    1 qt Qualco liq winterizer - no clear describtion but sounds like the above
    2 lbs of Qualco powder which is Alkyl Dimethyl Benzl Ammonium
    Gary
    New Haven, CT
    22,000 gallons
    domct203's Avatar
    Jun 2015
    CT
    3,513
    Quote Originally Posted by gtr1999 View Post
    Hi woody
    I used :
    Wow, that's quite the chemical stew.
    Are you dealing with some kind of non-organic contaminant?
    I close with the same thing I open with, chlorine.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2010
    East Texas
    9,274
    NONE of the stuff you added is required to close a properly balanced pool, so save yourself the money next year.
    Aug 2016
    New Haven CT
    62
    ok great, then I can wait till next weekend to finish it up
    Thanks
    Gary
    New Haven, CT
    22,000 gallons
    domct203's Avatar
    Jun 2015
    CT
    3,513
    I guess it could wait.
    I encourage you to consider not not using all those chemicals next year. Did you really throw a quart of something with 'no clear description' into your pool?
    Dom - TFP Guide
