Thread: Closing my green pool
    Jun 2013
    Marietta, GA
    10
    OK. I can read that closing a clean pool is best but that's not what I have. First time mom here let the pool get out of control at the beginning of September when our robot died (I'm way too busy to vacuum it manually for weeks). So I live in Atlanta with a vinyl liner, in ground, and have a mesh safety cover. What are the potential drawbacks (besides it being more work to open) to closing without adding chemicals? Could it damage the liner?
    I just plan on vacuuming up the debris at the bottom, I'm not adding chemicals because the water is already to low for the filter to run, finish draining it to just below skimmer, blow out lines, and put on cover. Of course remove ladder.
    If the water is too low to run the filter in the winter anyways won't the water lose the chlorine (bleach) eventually anyways and I wouldn't be able to add more?
    Thanks just want to get ready for worst possible scenario.
    18K gal, IG vinyl, Hayward Proseries S210T sand filter, 1081 pool motor? , Installed 1997, new siding in 2006, Dolphin DX3, North Atlanta, GA
    May 2015
    Union, NJ
    128
    Re: Closing my green pool
    I won't recommend closing the pool without getting clear water as it may have a negative effect on your liner and will cost you more in chemicals when opening next year. If not treated the water will get greener and develop more algae. Not sure if will damage your liner as my pool is plaster. However, I would think that the less chemicals you add the longer your liner will last. My suggestion you should shock and balance your pool water before closing. I always close my pool with a high chlorine level usually 20-30 PPM to account for lost of it during the winter. I do not know if such high level of chlorine will be appropriate for your pool due to the liner, but closing without any chemicals and green water is not a good idea.
    20,000 Gallons, 33.9 x 19.9 free form inground plaster pool 7 feet deep with Spillover Spa, Salt Generator (Fusion Soft),Heat Pump, Single Speed 2 HP Pump, D.E. Filter. Zodicac PDA, IQ900RS Controller.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,800
    Gonna be a heckuva lot easier to clear that pool now with lower water temps and sun temps.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,803
    Uganda, how old is your liner? At the very least, make sure you close with decent ph and TA readings...if your ph gets too low, it can wrinkle/waterlog your liner. If you have metals, you could get stains that are hard to clear. If you have oak leaves, tanin stains can take a few seasons of sun and chlorine to fade.
    Is your water already below the skimmer because you blew out the lines and drained the equipment? I don know if you ever get freeze temps in your area, but f you do, running the pump protects lines from freezing, so if you're not closing the lines thn you eed to bring the water up.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
