Thread: Speedstir with CYA
    Feb 2013
    Jupiter, Florida
    74
    Speedstir with CYA
    Not sure if this is dumb question....anyone use Speedstir for testing CYA? Better, worse, unnecessary? If so do you just measure in CYA bottle and then pour into the Speedstir Taylor vial and then into test tube?
    2006 IG 18.6K gal marcite saltwater w/integrated 800 gal spa, spillover, 2 Main and 2 Spa Drains, 2 Skimmers
    Goldline Aqua Logic PS-8, Aqua Pod Remote, Hayward GLX-Cell-15-W SWG, Hayward Pool Vac XL, Cartridge filter, single speed pump
    Taylor K-2006, Lamotte Borate Strips
    Jul 2015
    Central Valley CA
    1,119
    Re: Speedstir with CYA
    No need just mix it up in the bottle shake for 30 sec and you are good to go to start the sight tube test. Speed stir is best for tests where you have to swirl and count drops as the same time. Keeps you from loosing track of, or not getting drops in to the vial while you swirl.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Feb 2013
    Jupiter, Florida
    74
    Thanks, sort of what I figured but wasn't sure.
