Thread: Hayward Filter Maintenance Questions
    Wildcat's Avatar
    Jun 2013
    309
    2 1/2 year old Hayward SwimClear 425 sq ft, 4 element filter
    1. Gasket between top and bottom halves is expensive to replace. What does one use to recondition it to keep it supple?
    2. After 8-10 filter cleanings the filter bands are beginning to come apart. What do you use to replace them? Maybe some cable ties? Not overly tightened but tight enough to hold the pleats in place.
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Jul 2015
    Central Valley CA
    1,077
    Re: Hayward Filter Maintenance Questions
    For the gasket silicone lube like THIS, I use THIS because I brew beer and have it on hand. I believe it is basicly the same stuff and a bit cheaper since it is not "a pool supply"
    I don't think I have ever seen a post about band repair they do let loos over time but by the time they are totally ineffective it is usually time to replace the cartridge anyway. If I were to try to replace them I would seek out a local warehouse or freight packing store and see if you can get some plastic freight banding material and use a 2 part resin to hold them in place. Large Zip ties is not a bad idea either.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by atttech-2 View Post
    Thanks, this pointed me in the right direction. The gasket is $40 - 50 with shipping so I think I will try and preserve it. But the lube ain't cheap either. But everything is relative.
    Filters are showing little to no wear after 2 /12 years except for a few bands just starting to come off. But my filter is oversized for a 10,000 gal pool with four cartridges so maybe I need to clean less and each one doesn't wear as much.
