Results 1 to 9 of 9
Thread: Closing 1970's Anthony Pool
    mystreba's Avatar
    Oct 2016
    howard county, maryland
    2
    Sorry, I've been to the pool school, read countless posts and watched many videos. None seem to have my pool configuration. What seems clear is that you must get the sequence of activities right in order to avoid disaster. So I'd appreciate if someone who has experience with my kind of setup could validate or correct my process and/or assumptions about the setup.
    Note - see attached photos. Skimmer 1 requires two plugs (lower is for main drain, upper is for skimmer), and skimmer 2 only requires one plug.
    1. Backwash/Rinse filter and drain.
    2. Lower water level to 1" above the light fixture (approx. 1 foot below tile/skimmers, but still slightly above the returns).
    3. Bilge-pump skimmers and then plug them (all three plugs).
    4. Set MPV to Filter.
    5. Remove pressure gauge from top of filter housing and insert air compressor line (~25psi).
    6. When all water is purged from returns, plug them and simultaneously unplug skimmer 1 (both lower main drain and upper skimmer plugs).
    7. Replace upper plug in skimmer 1; when main drain blows bubbles, remove upper plug and quickly insert lower main drain plug.
    8. bilge-pump skimmer 1 again and insert upper plug; simultaneously remove skimmer 2 plug.
    9. bilge-pump skimmer 2 again and insert plug; simultaneously turn off air.
    10. Disassemble filter, clean filter element and reassemble loosely.
    11. Open and clean strainer, remove strainer plugs and close strainer.
    12. Install cover.
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Re: Closing 1970's Anthony Pool
    Welcome to the forum.
    While I don't have an answer for you, I hope this 'bump' will get your thread some new attention.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Mystreba:
    Before you do anything, please read this thread:
    1st Time Pool Owner - New Install Closing Questions
    You can follow the procedures in the post above regarding blowing out lines, etc. The plugs may be slightly different depending on your pump size.
    Your pool should be pretty straight forward. Regarding your Skimmer diagram, it appears that the pump (on the suction side) is pulling water from the main drain and from the skimmer. Logic tells me that the path of least resistance will go first. Therefore, it is recommend that you blow air from the suction side of the pump housing. This will push air back to the skimmer from the pump. Before doing this, plug the skimmer port with a Gizmo or black rubber plug. Now, air can only travel one way and that is to the skimmer and back down to the main drain. (If you do not have enough volume with your blower, you may never see the main drain bubbling). Once you see the main drain bubbling for at least 45 seconds to 1 minutes, then quickly shut off the valve for the main drain and skimmer (assuming it is one valve).
    Plug the suction side in the basket with a black rubber plug as extra insurance. Now move on to the return side. Set filter on circulate and plug the returns.
    Everything else should be covered in the thread and Pool School. Also, I am not visually able to see any shut off valves, either on the suction or return side (Please advise!)
    Please add your signature and Welcome to the Forum!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,384
    No-- there is a specific plug with a long stem about 8" to sit below the skim line & keep floor drain from rolling back.. It has 2 rubber expansion plugs on one stem... Get it from a&s or 3rd party.
    It's pretty slick
    mystreba's Avatar
    Oct 2016
    2
    Thanks all! I will take some time to read and digest. I do have the double-expansion plug but in eight years the pool company I've hired has never used it, and instead uses the 8" single extension for the lower drain. I do not have valves installed on the above-ground pipes, so must rely on the timing and placement of plugs.
    Jul 2014
    Connecticut
    1,384
    Or a plug built for the task at hand
    Catanzaro's Avatar
    Jul 2014
    2,256
    It's pretty slick
    Luckily, I have a straightforward set up with many Jandy Valves that isolate almost every part of the pool. Very easy when it comes time to close the pool, etc.
    Jul 2014
    Connecticut
    1,384
    I like easy closing a too - my first one (16.32 mesh) this morning - 26 minutes , covered , mechanicals & piping purged..
    Second pool not so easy 12" pipe, local water park - finished as the sun set
    Jul 2014
    Connecticut
    1,384
    Quote Originally Posted by mystreba View Post
    Just because they got away with it 8 times, doesn't make it a "best practice"
