Thread: Tiny hairline cracks / scratches
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Is there a way to prevent those tiny hairline cracks that form on the lip of most fiber glass pools and spas?
    I'm pretty sure this is only an aesthetic problem. It doesn't really seem to hurt anything, but I would like to stop new ones from happening. They are surface scratches or cracks on the coating on my fiberglass spa.
    Thanks!!!
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Tiny hairline cracks / scratches
    The only way to prevent them is good construction and a solid base. If the shell flexes at all under the weight of the water it will crack the acrylic, which is almost paper thin. If you notice any deteriorating wood behind the cabinet or settling on whatever base it's on, repairs to both will prevent future damage.
    There are various polishes that you can use to try to eliminate the visibility of the cracks. If you get a bad one it's a good idea to drill very small, very very shallow (like 1/32") holes at either end to prevent it from getting worse.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by spishex
    Thanks. The spa is attached to the pool and set in cement with pavers all around it. The only place I have cracks is on the small lip that sticks out around the tub. Ill post a pic.
    I have a lot of kids that are always in there and jumping into the pool off the edges and stuff. That can't be helping
    What polish should I go with?
