Page 1 of 13 123411 ... LastLast
Results 1 to 20 of 253
Thread: New Build - Frisco, TX
    Texas Dobie's Avatar
    Sep 2016
    Frisco, Texas
    171
    Good afternoon everyone!! I want to say thank you all so much for being able to read thread after thread and overload my brain with everyone else's pool build and questions! As you all know this pool process is a beating!! I think the pool builders should give away free margarita machines at the door!! My husband originally got on here when I started the bidding process so I also jumped on and read my little heart out. We originally just wanted a pool but then decided on adding a spa off the recommendation of a friend, we hope she's right . The spa will also help extend our season. A little background on us...it's just the two of us and our Doberman (who will most likely be in the water with us as well). We chose our style of pool and sun ledge with him in mind for cooling off during the hot Texas summer.
    We will both be on here asking questions through this process...so here's where we are so far with our plan. Any comments or suggestions are appreciated. I'm ready to swim!
    D
    Rsmith's Avatar
    Apr 2016
    Central Md.
    110
    Re: New Build - Frisco, TX
    Welcome to TFP! Do you have a drawing you could share?
    Central Md. 37 X 21 24K IG Custom Gunite with Anvil Quartz finish. Raised Spa.
    Sta-Rite Natural Gas Heater. Intellichlor IC-40 SWG, Sta-Rite 450 sq ft. Cartridge Filter.
    Pentair 1.5 Hp Variable Speed Pump. TF100. Dolphin Z-5. First swim 5/26/16
    Sep 2016
    Frisco, Texas
    171
    Rsmith's Avatar
    Apr 2016
    Central Md.
    110
    Looks great. The first thing that stands out to me is the first year of pool maintenance. What does that mean? Is someone else going to be treating YOUR water the way they think best?
    May 2016
    Dallas/TX
    280
    Quote Originally Posted by Texas Dobie View Post
    The pool process is a beating.... pool looks great! Good luck, who is your PB? I used Hauk Custom and they did a fantastic job. Not many PBs use Jandy out here.
    12K Gallon, IG PebbleSheen Blue Granite, built AUG 2016, 4 Jandy nicheless LED lights , Jandy 2.0HP VS ePump, Jandy AquaPure PLC700 SWG, PB4-60 Booster pump, Polaris 280, Jandy CV580 VersaPlumb Cartridge Filter , Jandy - Pro Series RS4 W/iAquaLink, Jandy JXi400NK 400K Heater, OK Flagstone Coping, Travertine Decking, 7 x7 Spa, Tanning Shelf, 10' Grotto, TF-100.
    Sep 2016
    Frisco, Texas
    171
    Rsmith, thanks!!
    D
    Sep 2016
    Frisco, Texas
    171
    Gocubs418, thanks!. Hauk had a great design but there were other things swaying us over to another PB.
    May 2016
    Dallas/TX
    280
    Gocubs418, thanks! We are using Prestige. Hauk had a great design but there were other things swaying us over to Prestige.
    I am sure it will turn out great, Best of luck.
    Sep 2016
    Frisco, Texas
    171
    Quote Originally Posted by gocubs418 View Post
    Thank you Gocubs418. If our pool comes out half as good as yours we will be satisfied.
    It's crazy how many pools are being built in our area.
    OH MY....This is winter time build is going to test my patience.
    R
    Sep 2016
    Frisco, Texas
    171
    Quote Originally Posted by Rsmith View Post
    Not necessarily, just trying to explore our options.
    R
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    Good luck! your pool is very similar to ours. I wish you a nice quick construction!
    Brian (Frisco, TX)
    2016 18,250 Gallon IG, Spa, Pentair Intelliflo VS, Pentair Master Temp 400k, , EastyTouch 8/ScreenLogic Surface: Pebblesheen Blue Surf with Abalone, Travertine Coping and Pavers. 3 LED in Pool 1 in Spa. New Frisco, TX Pool Build
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,876
    Following up on Rsmith's comment, I highly recommend not taking him up on the first year of pool maintenance (yes for the first month so the all is good with your warranty). You will become comfortable quickly after you take over. Honestly it's quite straightforward after you get the hang up it - and you have a great resource here. Your pool could suffer depending on how he maintains it. There is no substitute for personally maintaining your pool - no one will be more attentive than you (assuming that's your end goal anyway). You will likely learn bad habits if you watch a "professional". Their maintenance methods are not compatible with TFPC (trouble free pool care) methods because they only visit once per week.
    Please take a look through Pool School - link in the top left corner. Of first concern is your sanitation method. I see they have included a chlorine puck feeder. Have you given thought on how you plan to chlorinate? Now is the time to do that.
    TFPC's cornerstone is accurate self-testing and dosing. Only adding to your water what is needed and nothing else.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    TexasDeano's Avatar
    Aug 2015
    Frisco, Texas
    137
    Howdy neighbor. I'm in Frisco too and am going through my first pool build as well. My pool just completed the gunite stage. So I still have a ways to go. Your design looks great. I have poured over this site. The information and combined experience of everyone on it is invaluable.
    All of your equipment and materials looks good. The only things I would add based on my research is (1) look into cleaning robots if your budget allows it, and (2) a downside to the autofills is that it makes it hard to detect leaks, or other issues causing water to be lost out of the pool. So look into adding a flow meter to it so you can keep track of how much water is going in and compare one month to the next.
    Good luck with everything, and of course, post pictures to document your progress.
    Dean
    18'x24' Rectangle (3' 6" to 5' 5") - 11K gal. Saltwater w/ Blue Granit Pebblesheen
    Pentair equipment (IntelliFlo 3050 VS/SVRS Pump, 60 sq. ft. DE filter, Intellichlor Salt system, MasterTemp 400000 BTU heater
    Easy Touch 4 w/ Screen Logic automation, 3 GlowBrite LED Pool Lights) My build log
    Aug 2014
    Prosper, TX
    69
    Eugene with Prestige is a great guy. Hauk built mine as well. Best of luck through the process. My take is that it's not fun having it done (delays, lack of communication, etc is a way of life it seems) but well worth it in the end.
    20,000 gallons, In Ground, Pebble Sheen, DE Filter, Jandy 2 Speed, Attached Ground Level Spa, Polaris cleaner with dedicated pump, Ozone Generator, TF 100 w/ SpeedStir
    Sep 2016
    Frisco, Texas
    171
    Quote Originally Posted by bdrex28 View Post
    Thank you bdrex28! I was reading through your build and love your design! I remember seeing your spa with the drop seat and I am so happy you posted pictures of it, that is something I definitely want in the spa. Big thanks for that!! Sure hope they get yours finished up for you quickly!
    -D
    Sep 2016
    Frisco, Texas
    171
    bemoreswim - Thank you for the recommendation. We value the feedback from TFP members. I doubt we will use their offer of free pool maintenance for a full year. If our build goes according to schedule our pool should be done in February. Something seems appealing about having someone else cleaning our pool in the middle of the winter?? More than likely we will turn down their free year offer and go with a 3 month pool school to get us through the colder weather.
    No doubt, 100% agreed on maintaining our pool personally long term.
    R
    Sep 2016
    Frisco, Texas
    171
    We are leaning towards Wet Edge Primera Stone - Tahoe Coast for our interior finish. Any thoughts on this would be appreciated.
    R
    Sep 2016
    Frisco, Texas
    171
    It's been 4 months since we made the decision to build a new pool and patio and we finally have a signed contract and a projected dig date of December 5th barring any delays on permits/approvals from the city or HOA! We have made a few design, finish, and equipment changes from our original plan but the picture we originally posted is a good representation of our project. My wife and I are very thankful for the knowledge we have gained from the TFP community. Thank you. I'm sure we will have tons of questions for ya'll over the coming months so let me say thank you in advance for your ideas and opinions. I trust ya'll can keep a secret.....Rumor has it Santa will be giving my wife "D" a very special gift of a TF-100 test kit for Christmas!!!
    Thanks again,
    R
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    31,477
    What fun! A winter build! I love the design you posted! You are already so far ahead of the game just finding TFP!
    R, make sure to tell Santa the Speed Stir makes a great stocking stuffer also!
    Since you have read so much you will not be surprised with this request from me:
    Pictures of the area the pool is going AND a picture of the dog the pool is being built for LOL
    Kim
  20. Back To Top    #20
    Sep 2016
    Frisco, Texas
    171
    Kim,
    I know the drill....pics, pics and more pics!
    Here is one of the dog.....Amazing how much of the design was based on him!
    Thanks, R
