Thread: CYA Reducer?
    Sep 2016
    Escondido/CA
    636
    CYA Reducer?
    Seems too good to be true?
    Bio-Active 14430 Cyanuric Acid Reducer
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    pabeader's Avatar
    May 2015
    Dallas Ga
    4,071
    Re: CYA Reducer?
    It is. The few trusted folks who tried it, reported no success. Even after working directly with the manufacturer.
    Bob - Palm Beach by San Juan Pools. approx 5000 gals., Pentair 320 cartridge filter (all new guts installed by me), Goldline SWG, 'New to me' Kreepy Krauly Sand Shark, Intermec 104 Timer Test kit: TF-100 w/Speed Stir
    JoyfulNoise's Avatar
    May 2015
    12,844
    Re: CYA Reducer?
    ^^^ what Bob said....
    Matt
    Donldson's Avatar
    NW Ohio
    2,761
    Re: CYA Reducer?
    Yep, looked in to quite extensively last year when released. The only claims of anything even close to advertised results were either from brand new people who seemed only to join to push the product, or from people using less than accurate testing procedures.
    There are biological processes that break CYA down to ammonia but we have yet to see this done on a consistent basis. Also a problem is that for a heavily over stabilized pool the cost of removing the ammonia afterwards exceeds the cost of replacing water.
    The only 100% guaranteed ways to reduce CYA continue to be water replacement or reverse osmosis.
    Sent with Tapatalk on HTC Ten
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,179
    Re: CYA Reducer?
    What Bob, Matt and JD said.
    Sep 2016
    Escondido/CA
    636
    Re: CYA Reducer?
    I thought so. Thanks!
