Results 1 to 11 of 11
Thread: Top of filter is leaking
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    329
    I just noticed this morning that the top of my sand filter is slowly leaking water. I won't be able to check it out until later so I was curious offhand what I might be looking at? Is it just a tightening issue? Possibly a ring that need to be replaced?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Oct 2016
    Cave Creek, AZ.
    5
    Re: Top of filter is leaking
    Try tightening the black lid on top, or remove the lid if tightening does not help and clean off all mating surfaces, you shouldn't need a new quad-ring (o-ring) that's under the lid, you usually have to put some effort into removing the lid they can be tight, most likely a slight tightening of the lid is all that needs to be done.
    Replace the 0-60 psi gauge on top to, its old, cloudy lens and all,
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    329
    Quote Originally Posted by bigredmachine81 View Post
    Thanks, I was able to unscrew the lid pretty easily so I cleaned up the gunk around the lid and re screwed it back on and it works great. Thanks for the insight. And you are right about the gauge, it's been on my list to fix. Are gauges pretty standard and I could just get any that has the correct PSI range?
    Oct 2016
    Cave Creek, AZ.
    5
    Just get a generic 0-60psi back mount gauge, you have the original pentair gauge with the adjustable dial on it now it appears, unless you like the adjustable dial that reminds you when to backwash, i would just get the 0-60 without the adjustable dial.
    Don't get a 0-100psi gauge, don't get a liquid filled gauge, just get the gauge i suggested, pool's are not race cars so don't buy into all the hype, remember it's a hole in the backyard that has water in it, as long as you try not to let it get green, you should be fine.
    Doesn't anybody swim in the canals anymore!!....(a little Phoenix humor)
    (I am a pool repair tech in Phoenix)
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    329
    When I was growing up, I thought that if you went swimming in the canals then zombies would grab you from under the water and drag you under..... I guess all the PSA's worked on me as a kid.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    29,277
    , don't get a liquid filled gauge, pool's are not race cars so don't buy into all the hype, remember it's a hole in the backyard that has water in it, as long as you try not to let it get green, you should be fine.
    You DO need one of the liquid filled ones for them to last any time at all. I went through several cheap ones before I broke down and bought a "good" one (liquid filled)..........I have not replaced it after about a year now so it has paid for it's self!
    Kim
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    8,716
    Quote Originally Posted by kimkats View Post
    Kim
    I agree on the liquor filled gauge lasting longer.
    I much prefer the 0-30 gauge as it's easier to see the difference between numbers. On the 0-60 you can't see any difference in pressures at any position other than the "5" spots.
    Support the site
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by tim5055 View Post
    DITTO on both, 0-30 PSI & Liquid filled gauge, this gauge has lasted years and the lens is always clear TFTestkits.net
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Feb 2015
    Chandler AZ
    769
    I don't think a liquor filled gauge would last very long around here.
    But my liquid filled gauge from TFTestkits.net is working great!
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,196
    add me to the pile of satisfied tf100 liquid filled gauge owners. Mine's been in 1 year and works great.
    Dolphin E10 Cleaning Robot.
    May 2014
    Franklin, NC
    8,716
    Now, back to the original question of the OP.....
    From the looks of it I have the exact same sand filter. Mine has a slow weap at that top "O" ring also. I have removed the top re-seated and lubed the "O" ring with now change. To be honest, unless you can sit there and watch water flowing out I would 't worry. Mine is a little damp at times, but no gushers....
    Support the site
