Thread: Chlorine vs PH vs Alkalinity vs CYA
    May 2016
    Albany. NY
    3
    Hi everyone. I have a question about closing my pool.
    My Chlorine is high. 10+ range
    The PH is extremely low (6.4-ppm) and the alkalinity is pretty much non existent. The CYA i around 100 ppm
    Can I still close the pool and not have to adjust????
    15' round above ground pool. Cartridge filter. BBB method :)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,256
    Re: Chlorine vs PH vs Alkalinity vs CYA
    Definitely not. Get the TA up to 60-80 and pH around 7.5 first. More here on how to do that, Pool School - Recommended Pool Chemicals
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,203
    Please advise how your CYA is 100 when you are following the BBB method? Are you testing with one of the recommended test kits? Here at TFP, we rely on accurate testing. Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
